The cell you tried is probably too long. As a result, the light is not firmly closing the circuit on both sides of the inner tube. Try Sony VTC5, VTC5A or VTC6, or Samsun 30q. All should work fine.
I also had a similar issue with one of my FW3As. When I disassembled the tailcap I discovered that the “nubbin” was about 1/3 longer than my other FW3Xs. I replaced it with a shorter nubbin (I cut a piece off of a spare o-ring of the correct diameter) and the problem went away. It also made the switch feel very nice and tactile.
If you’re planning to submerge your light, it might not be a bad idea to disassemble it and lubricate the o-rings. It’s probably good enough as-is, but you never know.
Strange. Do you mean “thicker”? Or was the nubbin of a larger diameter? Mine was fine, just making for a very sensitive switch. I removed the nubbin, installed a 5/32” o-ring and switch has a nice firmness now.
I generally don’t have an issue with the firmness of the FWxx switch (I always use lockout), but this light in particular had a defect. The diameter of the nubbin was fine, it was just too long. It was physically longer than the nubbins in my other FWxx lights and was pre-loading the switch when the tailcap was tightened down.
I didn’t replace the nubbin with an whole o-ring, I cut a short piece out of the cross-section of a sufficiently thick o-ring to produce a new nubbin which fits in the original location. It’s a tiny bit larger diameter than the original but the rubber stretches to accommodate.
It definitely has made the switch more stable when pressing off-axis and has improved the tactility, even over my other FWs with properly fitted nubbins from the factory. It’s not immediately apparent to me why this would be. Perhaps a combination of the more pliant material and the slightly larger diameter?
I was always using lockout because of the switch sensitivity. But now I don’t bother with the 5/32” o-ring. I lock out the light when I put it away. Yep, I got that you cut the o-ring, but didn’t quite get that “long” meant “thick”. This o-ring segment technique is interesting. You can cut a variety of thicknesses to see what works best.
i didn;t think it had a manual memory [no memory] option…
one comment - it will do this [start on low], if you happen to hold the button down ‘too long’
it is a feature, to be sure you have a way to start on low
but you have to hold the button down maybe half a second
maybe your button is ‘sticky’ so that it thinks you are doing a slow press for start-on-low?
Manual memory mode on Anduril software is 5 clicks from ON (“5C”). Automatic memory is 5 clicks, but HOLD the last click, from ON (“5H”). See flow chart.
Edit — Oops. Looks like the Anduril version in the FW3As may not have selectable memory mode. Sorry ’bout that.
