M4D_M4X
(M4D M4X)
December 3, 2019, 10:58pm
1
Hello my dear friends!
Today i received the first pictures of the soon to be released
HAIKELITE HK04
SPECS (not final)
* ANDURIL UI
* 3x 18650
* LED choices:
– 4 CREE XHP50.2 ~15000LM ~750m
– 4 Luminus SST40 ~9000LM ~850m
– 4 CREE XP-L-HI ~5000LM ~950m
* USB-C charging port
* IPX7 waterproof
BLF members can also enter their username (please post that you voted!)
M4D_M4X
(M4D M4X)
December 5, 2019, 7:42pm
2
i found a Aliexpress shop listing the Haikelite HK04
beside some new pictures i add below there are more interesting specs:
(PLEASE NOTE: those information is not confirmed by banggood)
Specifications
Material: 6063 aluminum alloy barrel material; stainless steel pressure ring ; no
Stainless steel switch pressure ring , ultra-low internal resistance copper alloy silver-plated spring
Surface Treatment: Military Grade III Hard Oxidation
Lens: Tempered glass lens with anti-reflection violet coating
Color: Black / Desert Fence Yellow (optional)
Battery: Three 18650 power batteries (pointed, half pointed)
Charging: Type-C charging port, 5V / 3A fast fast charging,
When charging-the switch lights up red; when charging is complete-the switch lights up Light blue
Charging time: 3000mAh 3 sections 18650 duration 5 hours or so
Lamp beads: Four LEDs with three options: CREE XHP50.2
Or Luminus-SST40 or CREE XP-L HI Highest Level Glare Selection
Color temperature: 6500K (cold white) and 5000K (neutral)
Waterproof rating: IPX7
Product size: 140mm (total length) x56mm (headPart) x50mm (tail) x46mm (body)
Product weight: Bare tube 370g Package weight 586g
Packing list:
HK04 flashlight * 1
Waterproof O-ring * 2
Product Manual *
Portable hand strap * 1
Type-C USB adapter cable * 1
M4D_M4X
(M4D M4X)
December 27, 2019, 11:04pm
3
Hello my friends!
I was able to get it as public groupbuy! (no need to PM / mail / message)
please us my links to go to banggoods page for detailed information
if you want to share with your friends please give them the linkto this thread!
https://budgetlightforum.com/t/-/59790 (do not post the details anywhere)
And here is the deal which could be negotiated based on the feeler:
Th558
(Th558)
December 4, 2019, 12:58am
4
Wow. They actually designed something decent looking for once! XHP50s are pretty efficient so the sustained output should be pretty good. Nice to see there’s other emitter options as well. Wonder what the price will be.
Tubercle
(Tubercle)
December 4, 2019, 1:13am
5
Grossly inflated specs once again. Doubt the throw numbers can get close to what they state. Same w/ the lumens, that 4x 50.2 light is gonna put out absurd heat.
Then again, would be interested if they offer <=5000k tints which they’re not gonna.
SKY69
(SKY69)
December 4, 2019, 1:43am
6
I voted for the XPL Hi however I would be interested in any configuration.
SKV89
(SKV89)
December 4, 2019, 2:33am
7
Basically Q8 with USB-C recharge. Not bad.
mattlward
(mattlward)
December 4, 2019, 2:44am
8
Would love to see the XHP50.2 happen with a tint warmer that 5000k.
Voted for the XHP50. Looking forward to seeing the price on this.
rizky_p
(rizky_p)
December 4, 2019, 6:34am
12
afaik this is an upgraded Q8, now let see about the price.
Anthon
(Anthon)
December 4, 2019, 8:01am
14
why 3x18650? too little power for such lumens. And you need to buy a new set of 3x18650 cells because you can’t use your other 4x18650 cells from your other flashlights
mortuus
(mortuus)
December 4, 2019, 8:23am
15
hm not better using 21700 ? since its bigger then q8 makes no sense using just 3 18650…
Funzel67
(Funzel67)
December 4, 2019, 8:25am
16
Looks more like a competitor to Sofirns SP36 to me. Hope price is also in same range. And vote for 4000/5000k.
CM2010
(CM2010)
December 4, 2019, 8:37am
17
Xph50.2 and would prefer 21700’s.
Sillen
(Sillen)
December 4, 2019, 8:48am
18
Maybe 4 CREE XHP50.2 ~15000LM pending price
Di_Joker
(Di_Joker)
December 4, 2019, 9:31am
19
Yes, it would ideally be 4*XHP50.2 (4000K Hi-CRI?) and 3*21700
Satan
(Satan@103TFS)
December 4, 2019, 9:56am
20
Voted for SST40 and prefer 3x21700
