Lexels driver compilation
Since I got a D4SV2 I’m a big fan of Andruil with 1634 and RGB LEDs.
Lexel, do you have any plans to migrate some of your drivers to that architecture eventually?
Coming soon
15mm 2S
Sponsored by MascaratumB
was not here listed for some reason
Acebeam K30 (with mirrored tail board)
Thanks for your work Lexel! Just to let people know, this will be used in the LT Tool 25 and in some other 2xAA (soon to be 2x14500) flashlights !!
Thanks again and I’m sure other people will grab these too :wink:
I think this will be the final version
about 3.5 hours went into the design
Can this driver be used to drive a UV LED in a Tool 25 with 2x 14500? Will it regulate the current until the batteries are depleted to 6V?
Hi Lexel,
Will this work with Acebeam K30 GT with SBT90.2 LED?
The FET has no current limitation, the small current resistors have current limiting function but no regulation and are only useable with 6V LEDs
No regular 6V XHP
OP updated
15mm 2S drivers are now ready for production
I need one for my S42. Can you send me info on where I can buy one? I also have an issue with the charger in it. Can you replace this also?
I cant replace the charging board, only option to use it without
Ok. Where to buy the board with the new ui?
I must be overlooking it but where do I buy the new driver from for the S 42?
Send Lexel a Personal Message with your driver request info. It’s the blue button under his name that says “Send PM”.
Oooooooo PM coming
Okay, so I’ve pulled apart my MF01 driver (the buck one, v2.1) that I got from you; everything’s working fine, just re-wiring it. Just testing with the DMM and I seem to be getting 140-150 ohms between LED+ and LED-. Unsure if that’s expected behaviour; seems to be happening on both sets of emitter wires. Open to thoughts! I’m reflowing it now on a heating platform in case I’ve done something stupid somehow.
OR
Is it possible to get this image redone without the components on it, so I can trace and isolate?
Measuring this is no defect its just that the Shottky diode gets conductive by your DMM
they respond very fast and can deliver high currents but also have a quite considerable leak current
diode test shows me one side about 0.1V the other side 2.8V
a proper test would be a current-limited source of like 1A and then measure the current in both ways
Awesome, thanks mate. Was just re-doing my wiring on it, and got a short (thankfully tested before putting power to it), and have been chasing it down and then noticed that.
phew
The buck chip has no problem with shorted output, it will just leave you in the dark till its removed
28-30mm up to 23+1 AMC driver Bistro or Anduril
Boost drivers:
UV-C and UV-C+UV-A drivers
standard is 500mA 7.8-8V for Klaran 275nm LED, 17mm 2 AMCs for 365nm LED, 20 and up to 4 AMCs for UVA
17mm UVC, UVC+A
20, 21, 22mm UVC+A
