I just put my Cu Tool w sw45k LED mod on my light meter and it gives 2.3 lumens, 20 lumens, and 80 lumens. The difference is obvious. This particular head is actually a lego of a Maratac head (dont believe their ridiculous lumen claims). I get similar outputs from a Tool Head…
When I got my last 219c Cu Tool, the maximum was 110 lumens. Thats more lumens than the 219b that I prefer. The 219c is greener.
My Cu Tool always has a battery in it, as it is my most used aaa light. I dont have any mode issues.
Great idea, Keith. I found a wire, stripped the ends, and completed the circuit. And YES… now it was clear to me the difference between medium & high. I noticed even medium is brighter without the tail cap. So apparently there must be some kind of current regulation going on in the tail cap and mine is faulty. I installed the tail cap after this test, and now I can’t even get mode changes working properly again. It’s either some sort of medium, then a medium-high, which starts out a little dim while switch is still depressed then brightens a little upon release of button. No low. Hopefully the replacement will be OK.
Even dumber design, then. You have to charge a separate lithium-ion battery in the tailcap, every time you change the “main” battery? I don’t believe it.
I think they’re faulty units. The “charge the tailcap capacitor” is a dumb excuse.
WTH? Nobody makes a flashlight electronic switch like that. Why would they? A li-ion battery would eventually require replacement, having far less lifespan than a capacitor. And a tiny li-ion battery sandwiched inside a tail switch certainly wouldn’t be user serviceable.
See paragraphs [0011] to [0014] if you understand electronics and can get past the machine translation.
EDIT: added pic from T18 in the other thread. Note there’s one more component on the other side of the board (the MOS?) that matches what I can see at the base of the spring on my MassDrop light.
I just got my order for 10 Supercaps today from arrow electronics for building Loneoceans GFS16 FET switches. Ordered a few for spares.
The Seiko Supercaps are tiny and look just like a coin battery. Its only 4.8 mm in diameter. https://www.arrow.com/en/products/xh414hg-iv01e/seiko-instruments-inc
It could be the same one used in these tool switches, I will check next time I take one apart.
Edit: I can confirm it is this exact SC, the Seiko XH414HG-IV01E.
if it’s a supercap then it should charge in seconds, not minutes
and something doesn’t make sense.
if it needs to be charged before use then it means there’s no battery inside?
and there was never a battery inside, no testing with a battery at all?
either that or the supercap lost it’s charge. so that means that thiswill just drain the battery all the time.
probably not a good idea to make switches like this
Charge time will depend on how much current is provided. The current could be quite low if the supercapacitor is in series with a large resistor (e.g., R3 and the BAT in the patent schematic).
Yup. A supercap is certainly not low self-discharge. It will continue to drain the battery as it continuously needs to be topped up with charge. You have maybe a month of shelf-life before your battery is drained by the supercap.
Yup. This stupid flashlight design.
Everyone else seems to be able to design lights with switches that can run off the main battery, and don’t need to be charged for an hour before you use it.
I still think the units must be faulty. I’m having a really difficult time believing anyone would design such a ridiculous switch.
I’m not sure your speculation matches what others have experienced with these switches that seem to have been used for over 4 years. Here’s a comment in the other thread
I'd like to know the parasitic drain of the switch assembly, but like I said, my (crude) multimeter measures nothing.
Note if parasitic drain is an issue and I need to leave the light sit for a month, it's easy to lock out by loosening the head 1/4 turn.
