I could definitely go for a bare aluminum lantern. If that happens though, I really should make a small change to the firmware to make factory reset easier without anodized threads.
That would be the one issue with a bare version, is there will be no 1/4 turn mechanical lock out.
Are you on the original GB list of 3000?
One sand-blasted please!
I’d “spend” one of my GB numbers on a bare Aluminum.
I know I’m missing something, but I don’t know what it is.
(otherwise it wouldn’t be missing )
I’m looking at TK’s operational graphic HERE , but I can’t figure out from which mode I do a 3H to get into tint ramping… or how to ramp once I’m there.
Any mode. It’s a global mapping, so it applies everywhere there isn’t something else overriding the 3H action.
Just “click, click, hold” and then let go when the tint reaches the desired color. If it goes the wrong way, release the button and try again.
Button events fall through a stack of “states”. If a state handles the event, that’s the end of the story. But if the state doesn’t handle that specific event, it keeps falling through to the next state… and the next, until something handles it. The tint ramp state is on the bottom of the stack, so it works anywhere… as long as the event isn’t mapped to something else at a higher level of the stack.
Not sure if that makes sense, but basically it means the tint can be changed at almost any time.
Yes DBSAR, I am on the list for two. Numbers 2439 and 2440. I know there were a lot of people on the list well ahead of me so it’s not a big deal waiting in line behind them.
Have you checked your messages? Everyone should of gotten a message by now, if not message sofirn.
I’ve seen a few photoshopped images showing possible colors, but I’d like to see some actual pictures when the color versions are in production. I’m a big fan of green but orange would is right up there with my favorite colors.
if you have not received any code via PM, please send Sofirn here on BLF a direct message with your list #number.
Sorry. Sent one code just now.
Thank you all.
Received the code from Sofirn.
That makes perfect sense. It turns out that I was just being a bit dense I saw the 3H from Off for the fancy blinkies and my brain refused to connect the dots for Tint being 3H from On.
At least I didn’t do anything /really/ embarrassing, like ask a question I’d already documented on a battery wrap & function cheatsheet that’s linked in my sig line… :partying_face:
Thanks
+1
Or, at least some representative samples of what the color will look like.
Depending on the actual colors, green(olive/forest) and orange could be great. Splitting off some threads for an interest list for colors and issues and such, and linking them in the OP might help keep this thread from greatly exceeding semi-gargantuan, and sounds like a good idea if they actually get used instead of everything still being posted in this thread. lol :person_facepalming:
If there’s a tally, add me: I’m planning to wait for colors for some of my remaining numbers, but also would be interested in an un-anodized, etc., version as well.
I agree. Maybe Barry could post something coated with the actual colors from the factory that does the anodizing. It doesn’t even need to be a flashlight. It could anything made from the same type of aluminum so we could see what the color shade and finish would look like.
I would prefer to see an example and not just a Photoshop of the colors before committing to the list if they start one. The tan is supposed to be a flat finish, but I was thinking the orange and the green were going to be anodized which looks much better than the flat paint look for those colors.
I received a code a while ago because I am somewhere between 1000-2000 in the list but never used the code because I’ve been waiting for an orange lantern. Will my code still work or will there be issues? I really want something brighter than black so I’m willing to wait for it.
I was told by Sofirn that the code will be good thru December……
I am unsure how long the codes last or if they expire, or will work for the later batches. maybe Sofirn or Barry can answer that.
