A funny thing happened on the way to the forum........
What makes the OP think that the Flashlights themselves all same model coming off same assembly line on the same day are within 0.5% tolerance?
They’re not due to the fact that the LED itself does not have that tight of spec.
From Zebralight to Convoy this is just not going to happen.
Which is why crying over a 10% output difference, or even 20% is stupid
Not only do mcgyver setups have variance with actual lab setups and conditions …
Even IF the difference is real, you really dont notice it in real world usage
The difference between 1000 vs 1100 or even 1200 lumens wont be noticeable if you close yr eyes for a few seconds :wink:
Exactly. Isn’t there a phrase that has floated around, called “tint lottery?” The idea being that the same emitter and bin designation can have variation. I can’t locate the topic, but I have a distinct memory of a Zebralight discussion about emitters regarding an SC700W. There were some complaints about emitter tint. Someone posted about having two of these, and side-by-side the beam tint from the same emitter type in each light was slightly different.
You don’t. Nobody does. The LEDs are only specified to a 7% tolerance. Basically, all spec numbers in the entire flashlight industry can be assumed to have at least a 7% margin of error. Add in the variation from other components, and it’s probably more realistic to assume at least 10%. And that’s before taking into account that there are multiple different definitions of what a lumen is.
People can get pretty accurate measurements, even with cheap gear, if it’s designed well and operated well. But none of the numbers are very precise. If a light is specified to produce 1234 lumens, that means it’s probably somewhere between ~1110 lm and ~1360 lm… and the actual value is expected to be different even for two lights of the same model.
Getting higher precision in this field generally requires many data points to be able to determine where the signal is among all the noise of random variation.
OK people, thank you all for your sage words of wisdom. I feel suitably schooled. Forgive my ignorance. However, I have a couple points to raise.
First, I didn't realise that there is no absolutely precisely measureable torch output, either between identical examples of the same torch or in any observers/testers ability to measure any torch output that accurately. A reasonable tolerance posited was 10% I think. Well, on a 1000 lumen torch, that's upto 100 lumens either way, which as pointed out will hardly be noticeable. However, on a 100,000 lumen torch, that's up to 10,000 lumens either way. I don't know if that's noticeable by eye but I'd be concerned that my stated 100K lumen torch is actually only delivering 90K worth of lumens. Of course, I'd be smiling more if that same said torch was actually outputting 110K worth of lumens. But this brings me to my second point....
Most of you have asserted that either you or others can and have made relatively accurate torch output measurements, perhaps more accurate than the manufacturers themselves. Well, how do you actually know that to be true? If there is no absolute method of referencing and the testing procedures and testing equipment can vary so much as to substantively affect the results, how do you really know that your own results are that accurate or more accurate than anybody else's results? My point is that without a scientific procedure carried out according to a proven recognised standard, that is repeatable by others and with results obtained being either identical or almost identical between different testers, any claims to having obtained accurate results seems rather erroneous, no matter who the tester was, what they used to test and the method they used to test.
Therefore, it matters little if people claim their testing has produced 'more accurate' results because none of that is verifiable in absolute terms. However, when a manufacturer states their figures which have been obtained under proper lab conditions, assuming they claim the ANSI/..... standard, a casual observer has to believe those figures over those claimed by others who's methods and equipment cannot be verified as meeting or exceeding the conditions stipulated by the international standard. So, why wouldn't the casual observer believe the manufacturer's figures over and above those made and claim by others without knowing whether the recognised standard's conditions had been observed? This assumes that the manufacturer: a) knows what they're doing and b) are truthful about the results they obtained, either of which I'll grant cannot necessarily be taken for granted.
It would really help the group to envision whiteheat1963’s comments as coming from Sheldon Cooper of Big Bang Theory, makes it kinda fun that way at least.
Now then;
They would and should believe the manufacturer, if they followed the protocols for ANSI however flawed that system may be, it’s all we have.
Your points are squat.
Nowhere do I read that anyone said their system was
“perhaps more accurate than the manufacturers themselves” as you have said.
You are Trolling and you have been found wanting.
Troll on somewhere else.
Try again Skippy.
New members often seem to be the ones that make the most noise… then while the majority of them later settle down, a few decide to try knocking lamps off tables & see what happens. :person_facepalming:
How can we know any specification is real if we can’t test the manufacturer’s claims with similar equipment? Hmmm…
And now I’m worried if my car really has 205hp, or that it might just be 199hp. Won’t be able to sleep now…
Whiteheat1963, are you referring to posts in which the poster has directly challanged a manufacturer’s output claim because of measurements the poster made on homegrown apparatus, or have you seen posts about the inaccuracies of home-testing as well as posts refuting manufacturers claims, and linked the two?
If the former it would be useful to see the posts which directly challenge manufacturer’s claims as a result of home testing to be able to comment on them.
If the latter, well, if a manufacturer claims that a torch with optical and electrical losses has the same output as the bare LED under lab conditions then you don’t need to measure anything to know that the claim is bogus.
And, welcome to the forum :slight_smile:
Yes, it was the latter. I don't exactly or rather, that precisely know what a manufacturer is claiming, so I don't know what is real, unreal, bogus, really close with minor inaccuracy or just imprecise for whatever reason, and thanks for the welcome to you all who have offered a welcome.
Hahaha! Love it. No, not trolling, never have, never will. However, I get the trolling label. Even so, my question/statement was legitimate and stated in a perfectly civil and balanced way. Well, I guess the Asperger's syndrome in me comes out as Sheldon Cooper - who ironically I think would never troll. But thanks for the welcome nonetheless.
Hi mate. Thanks for the welcome and all this extra info that I ws unaware of. Appreciate it.
You are right, Sorry to be rude;
By all means, Welcome to the BLF!
Enjoy your stay, try the veal, etc.
Stay calm, don’t be alarmed, it’s just a holiday back at the funny farm.
Peace out.
Keith
No worries. Totally at peace. Enjoyed your poem too.
Ha, I like this guy. Let’s try not to scare this one off.
Awww! No need to worry about it. I'm not skittish, at least not anymore. The grey in the hair and in the beard has hardened me to all sorts of initiations. But thanks for the vote of confidence.
One way people have improved the accuracy of measurements in the community is to build light integrating devices which give pretty consistent readings regardless of the beam shape or angle of the light being measured. For example, if a laser-like light gives the same numbers regardless of which direction it is aimed in an integrating device, then that device probably has good integration qualities. One person who has done a fair amount of work in this area is djozz, who commented above.
Another way people have improved the community’s accuracy is by distributing reference lights which have known amounts of output. Basically, measure a light in a high-quality reputable integrating sphere, note the numbers it produces, and send that light to anyone in the community who wants to calibrate their own sphere. Then measure more lights in the same original sphere, so that many people can calibrate their spheres in a way which agree with each other. Ideally, also measure a variety of both floody and throwy lights in the original high-quality sphere, so other people can make sure their devices are accurate regardless of beam type. Maukka has done a lot of this work, and greatly improved consistency in the community.
Similar to that last bit, some have also taken trips to officially-calibrated spheres used for standardization purposes, and/or purchased calibration reference lights from standards agencies, to ensure that our measurements are similar to the standards.
All of those things help, but for some types of measurements, none are actually necessary. For example, if someone tests a light before and after modifying it, the relative difference between measurements can be very precise even if the absolute numbers might be skewed. So we can get numbers for things like “this lens allows 99.5% of the light through, but that other lens only allows 97.7“. Or ”this ZL SC52 makes 5.5 more lumens than my other ZL SC52”.
Perhaps more to the point, it’s also possible to detect things like when one brand uses a different definition of a lumen than another brand, because their numbers are consistently higher or consistently lower than expected. There are at least two different known “lumen” values in use by flashlight companies, and they differ by about 30% or 40%.
… and there are also rather a lot of flashlight brands which make up numbers for marketing purposes, with little or no relation to reality. Those are usually easy to spot, even without measuring anything. Like, if a light uses a Cree XR-E emitter and claims to make 800 lumens, it’s simply not true.
For a true 100,000 lumen light though, all of those so far have quite a few LEDs. This actually makes things more precise and consistent, since the individual variation tends to average out to produce a much more predictable result than one could get with a single LED. There are still plenty of other sources of variation, like the driver components, the battery type and state, the amount of dirt on the contacts, and even the temperature… but at least the LEDs can be a bit more consistent.
I hope this answers some questions.
Yes, it does. Much appreciated. My vault of knowledge increases daily.
You can do what some of us do here to get close lumen numbers from flashlights.
Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available Lumen Tube
WTS: Calibration lights for DIY integrating spheres / lumen tubes - 67 € - Calibrated lights
Adjust the diffuser’s to get the reading as close as posssible with both Calibrated lights.
This will measure OTF lumens.
Well, you may not believe it, but this thread was started because I happened to read various contributors posts which made me doubt the actual output of a particular torch that I own. So, I wanted an accurate, quick and easy do it yourself method of testing the torch's output. Well, it turns out that this is just not going to be possible, so I'm just going to carry on not knowing if the stated output really is as claimed. But thanks anyway - I can't see myself going that deep in to it as I don't have the tools or wherewithall to do most of this stuff.
Oh well, as for me, if l need more illumination and l have one illumination tool ready at my disposal, then I’m fine.
