Fellows, please don't delete your posts right after publishing them unless you absolutely don't want to say a thing. I mean, edit and change whatever in them. When you delete a post and create another right after, the thread answer notification becomes invalid.
I wondered when I saw the Colaier G35 cells advertisement if that was as good a deal as it appeared. Thanks for commenting on it.
Hm, Colaier also sells the Lii-202 charger for several dollars more than other places that have it marketed under their own brand. Hmmm.
By the way:
Photos from a french fellow review in this sale ad: https://www.aliexpress.com/item/32811943155.html
Wow! :facepalm: He built an e-bike battery pack where he is using a thin wire to carry all the current from each battery stage (up to 30A or more). Creepy! Hope he is fine, really. I would have used ≈5x AWG20 wires or 5x (2 × 0.25) mm² solder wick patches for that same requirement, better safe than sorry.
Mon, 12/02/2019 - 03:54
+1
I don’t care of Ali will save me shipping and a few cents on cell price, I go with nkon for peace of mind.
Looking for a cheap single-cell charger to include with flashlight gifts. Had my eye on the Liitokala Lii-100, but can’t find it from a US supplier.
Does somebody know where to get it in time for Xmas?
Or can you suggest another?
Must have
Less than ten bucks, preferably a lot less.
Single-cell, multi-size.
Lithium or NiMH Charging (I think NiMH capability is important when giving to muggles, a bit of idiot-proofing.)
A charge percentage indicator, not just a red-green light. 25-50-75 percent.
Power bank is a plus, not required.
USB, no wall wart needed.
Deliverable in less than two weeks.
If you wanna gamble, these may arrive on time with ePacket or AliExpress Standard Shipping:
- https://www.aliexpress.com/item/32952599838.html $6.52 ePacket, 12/22 expected delivery.
- https://www.aliexpress.com/item/32961682210.html $6.32 ePacket 12/23.
- https://www.aliexpress.com/item/4000154269090.html $5.60 ePacket 12/23.
- https://www.aliexpress.com/item/4000112002327.html $6.63 Ali-Std 12/22.
- https://www.aliexpress.com/item/4000167579953.html $5.95 ePacket 12/23.
- https://www.aliexpress.com/item/33009931591.html $6.94 ePacket 12/21, $6.63 Ali-Std 12/22.
- https://www.aliexpress.com/item/32850497130.html $5.99 Ali-Std 12/21, handled by AliExpress. ⟸ Maybe this one.
I bought and tested 4 of these. Not for NiMH but good product, great service and close to you too!
And they have name brand 18650s for less than $3!
I like the idea with a voltage display on a single cell charger.
The multi chemistry feature can also be very useful and the two currents means more battery sizes can be charged at a good rate. It seems that Liitokala is the only one doing this on a single cell charger.
Can insert the battery in either polarity, another unique feature.
It looks like they started in business by selling more complex cell analyzers, and only then moved to regular chargers, and that’s why they continue with the extra features.
However, on further inspection I decided the user interface is too many options to gift to The Muggles. I will give them plain Li-Ion chargers.
I had not yet seen the new S1 charger with digital display. Will get one of those for when I’m traveling light.
Thanks for the help.
Since I don’t vape anymore I’m less concerned with a battery blowing up in my face as I once was. I’ve personally bought 8 of these. https://www.aliexpress.com/item/32888419252.html?spm=a2g0s.9042311.0.0.58934c4dNTg4bQ
All tested above 3200 mah and 6 months later have not had any issues with them. These are Chinese batteries. Do I trust Chinese batteries? If they test right and are consistent, then yes I do but hey that’s just me. I trust my wife too, though she could be out blanking sancho every day, I don’t have evidence of it so I’m good. I would buy them again without thinking about it.
Did anyone test this one to see if it actually can handle above 1A discharge ?
First of all, the link you posted above is bad (use full links). Here is it fixed:
Nearly guaranteed that is some energy cell from a chinese OEM. I could find someone who took a photograph of a cell in vertical position more or less showing the top:
Not the best photo either, but at least I can discern a penta-lobular/penta-legged top. This means the cell is most likely from BAK (photos clearly showing particularly top and maybe bottom from cells are very important).
Discharge rate presume 2C, maybe 3C if lucky. 35A? You know that is a lie. :facepalm:
I ask because I received such a cell and did a discharge test. It heated at 1A enough to make an Opus pause.
I will take a look at the cap, thank you for the tip.
Official specs say 35A bursts and 20A continuous.
(Fixed the link.)
Just one cell, Overmind? Overheating at 1A for a cell that size is certainly a problem. Could be a faulty cell.
The Opus (BT-C3100) is also known to have problems with heat when discharging multiple cells at once at 1A.
The only official specifications I know of are in manufacturer datasheets. Those 35A burst and 25A :facepalm: continuous figures are outright potentially dangerous fabrications from whoever is rewrapping the cells (LiitoKala from http://liito-kala.com/, in this case, store number 133859 in AliExpress, which I'd say is not the same as LiitoKala from http://www.liitokala.com.cn/, store number 217753 in AliExpress, and the ones who started with this thing).
Bear in mind the li-ion industry has never been consumer oriented. The big li-ion manufacturers (Samsung, LG, Murata and Panasonic/Sanyo, or the big 4) do not feel at ease with this idea because proper use and management of li-ion cells requires a minimum level of knowledge and responsibility. In the chinese market there is a good deal of battery OEMs (some quite big but little known versus the big 4), and many companies buy bulk quantities of cells, rewrap and sell them to consumers with varying degrees of morals, professionalism and honesty.
I checked and the cap is a quad not tri or penta.
Hi, new user here
Does anyone know if Vapcell store is legit?
I would like to purchase Samsung 30Q from them, however, in their listing I can’t see any reference that they sell Samsung cells. The product page description says “no fake”, but they also write “Vapcell original 18650 3000mAh 20A 30Q”, which makes me wonder if it’s a branded cell of Vapcell or a genuine Samsung cell. Screenshot:
Another thing to be suspicious of, the 30Q cells are 15A and they rate them as 20A.
Vapcell has quite decent reputation, but after all it is a rewrapper; with this I mean they can still stick whatever rating they feel comfortable with over any cell.
Different OEMs abide to different in-house rating standards. LG, for example, rates “20A” its HG2 cell despite being slightly lower performing than a 30Q. Samsung tends to be conservative with ratings, whereas cell rewrappers long to stick the biggest figure they find acceptable in their wraps (even if some times it is an outright fabricated and dangerous lie). A 30Q cell, with temperature protection, could be used fine at ≈20A.
P.S.: you can find other providers of 30Q cells besides Vapcell. In the european market, NKON is a well known distributor.
Thanks for the informative reply, Barkuti.
Despite declaring the cells as 20A, do you think the cells are genuine?
About NKON, I used to purchase from his store but he no longer ships to my area.
I read through this thread and also came across Aliya and Lucky store. Are these stores
sell genuine Samsung 30 cells?
Yes, I think the 30Q cells Vapcell sells :-D are genuine.
Aliya's Battery & Lucky Electronics are known to sell brand genuine batteries. This doesn't means you should presume that everything they sell is genuine, they also sell other strange cells like some green wrapped 26650s Panasonic style (take a look: 26650s @ Aliya's Battery, 26650s @ Lucky Electronics) which, as far as I know, are not Panasonic cells. Far from it.
If in doubt, sell any of them a message with whatever question.
It never hurts to send them a message to see what can be done. O:)
I’m mostly interested in Samsung 30Q cells. I’m also aiming for 25R and LG HG2.
Hope to get genuine stuff with those cells at least.
I’ll contact them but in my experience with Chinese sellers, they don’t care to lie if it
will make you place an order.
I did try with no avail, it was last year when I asked so maybe things have changed, although I have my doubts about it.
