I’ve had the same amaloop nimh aaa in my ti tool for well over 6 months and it still works fine. Parasitic draw mustn’t be too extreme.
What I like most about the eswitch on these Tools, is that it seems like it would be nearly impossible to have them come on in your pocket at any level other than low, which means that you’d have a long time to discover it before the battery could be drained to an extreme degree.
I think that the UI is a bit awkward, but it’s very good for assuring only low mode turn-ons in the pocket. Any accidental turn-ons seem pretty unlikely with these switches, anyway, since they’re not proud of the tail cap.
It is what it is I guess, but mine has been sitting in Hebron (roughly 10-15 minutes from my house) for several days with no update…
I dont think this is the exact circuit for the tool. Notice the schematic has 2 diodes D1, D2 the tool has 1 and the schematic has 3 resistors and the tool only has two.
The tool probably is real similar but maybe with a updated IC that doesn’t require as many extrernal components. As you stated R3 should be the current limiting resistor for charging the SC. In the GFS16 it also has a current limiting resistor for charging. I set mine at 100 ohms and it takes about 45 seconds to charge up enough to start turning on the fet. I don’t know what value resistor the tool uses but it could probably be lowered slightly to improve the time it takes to charge.
I’m not sure what all the fuss is about with the switch charging times, mine works from shipped state in about a minute of the battery being inserted.
Once the SC is charged its good to go. To me its the whole reason this light is so appealing to me. Its a cool innovative design with low resistance switch with almost no parasitic drain that very few lights offer. I dont know exactly how much it does draws once charged if any. The reason it has almost no parasitic drain is that nothing is using any energy while it’s waiting for user input from the switch. Its idle with the SC charged. Then once you hit the switch the SC supply’s the circuit enough to turn on.
No mcu using power waiting for user input from one ground pin to turn on and run the code. The tool switch is a very effecient cool design in my opinion. It even has a Super Capacitor, what could be cooler than that.
Yeah. Somehow this is being blown out of proportion. Even mine took maybe a few minutes to work normal. Even if it takes hours for the first time, I personally don’t see that as an issue.
The Massdrop Vega (Lumintop Tool AA) is available for preorder - 30$.
Is an emitter swap simple and straight forward? Mine came as Cree instead of Nichia. I haven’t opened it yet.
If the emitter is an easy swap I’ll keep it. If not, I’d rather gift it without opening it.
Go for it and let us know
I have not tried, but Ive had several modded for me by others
here is an sw45k in a Maratac head, on the eSwitch Tool body
Thanks! This looks interesting. I will add the link to OP for reference.
Its pretty easy if you can reflow another 3535 emitter on. No glue used, just unscrew the pill, pull the led protector out and unsolder the positive and negative wire to the mcpcb. Pull the mcpcb out, unsolder the led off the mcpcb, reflow emitter of your choosing back on. Place it back it the pill with a little thermal compound sandwiched in between and solder the wires back, add the led protector back. Screw the pill back in and your done. Its one of the easiest lights I have done.
I think I remember one model using a aluminum mcpcb maybe one had a copper mcpcb (not sure). Copper is really not needed in such a low current light.
Awesome. Thanks! Seems simple enough—I’ll give it a go.
still waiting for my CuTool
took 6 days to reach USA
spent 10 days in Illinois
and is now in Texas, just one state away from me
so far it has taken 17 days in shipping, and I dont have the light yet…
possibly the worst delay in a drop purchase I have experienced… thanks to them using DHL
but, soon enough it will come
Weird. The few times I’ve used DHL from China, it has taken about 2 or 3 days to get to me in Canada. But it’s costly.
Weird.
normal for me
DHL received a package for me in Germany on Nov 19… tracking says it is still there… thats 18 days with no sign of the package reaching USA yet…
DHL Express, and DHL Ecommerce are two very different shipping methods. Not 100% that Ecommerce is correct name, but whatever it is called it is the economy side of DHL. And in all cases I’ve had it used for shipping it is way slower then Epacket. Seems to get in the US fairly quickly, then in my experience takes weeks bouncing around multiple states before it is finally delivered.
Slowest shipping I’ve experienced thus far.
It also seems like DHL Express has taken a big hit on speed lately. About six months ago they were 2-4 days to me from China, now they are barely faster then Epacket which typically is 7-10 days for my local. DHL Express starts at about $15.00 added to cost of item. The biggest benefit in DHL Express is accurate/quickly updated tracking so for more expensive packages worth it to me.
Both Ecommerce and Express DHL all the delays seem to be once it hits the US.
Following the trackin number I discovered the next message: "04.12.2019 10:16:01 [China Post]
[Guangzhou International] Return, Remarks: *Returned by security check*".
:O :FACEPALM:
I asked the Drop's customer service and they asked me if I want a replacement. I said "of course, but this time, send the correct (Cree) version."
I am waiting for an answer/sign from them.
mine took about 2 weeks
wle
The Drop's CS told me that they shipped it again.Will see if a tracking number pops up.
The Nextool Flagship 16-in-1 Pro Multi-Tool is $30 on Drop.com, and has been for a while.
If the $20 off promotion works on this item, the total will be $10.
https://drop.com/buy/nextool-flagship-16-in-1-pro-multi-tool
Thread on the Nextool:
https://budgetlightforum.com/t/-/57193
I don't know if the Nextool on Drop.com has locking blades, however.
Just to update the resistor mod for changing low and med resistors. Changing them around on the Lumintop aaa tool, (not Drop aaa tool) does not work. You will end up with low,low, and high. This is for the Lumintop version that has med, low, high in that order. I think the reason is that in med the current runs just thru the med resistor (1 ohm) so changing it to a higher resistance (10 ohm or higher) gives you a low in the first mod. But when you click on off for the next mode which is original low mode, now the current switches to run thru original low resistor first which is in series with the med resistor to the led. Now the current is running thru both resistors and is low also. I havent probed around with the circuit actually running but in my lumen tube both modes (med and low) produce about the same lumens with the resistors switched around. I think this could probably be fixed by cutting the traces to the fet’s gate and rearranging them. I havent tested that yet but when the mode contoller or mcu (not sure which it is) says turn on med first instead it turns on low fet and when it cycles to next mode it says turn on low fet and it would turn on med fet. No resistors would have to be changed. Its just a matter of fouling the controller in which fet to turn on. If anyone happens to try this please post up your findings. This will probably not be easy to do since its so tiny, so try at your own risk.
Please note this is for the original Lumintop AAA tool not the Drop tool being discussed in this thread. They are the same except mode order. Changing the low resistor to a higher value still gives you a lower low in either version of the tool.
