The edge of the spill has a square shape with faded corners. i.e. it looks like there are four auxiliary emitters, or it’s an equivalent effect by the optics.
Since you’re in the US, you can add the USB cable for free. I can confirm the i1R 2 EOS did not come with the charging cable, and it is not offered in (all?) other countries.
Comparing to the Sofirn C01S, the build quality of the i1R2 feels better, the threads are smoother with practically no play, and it turns on solidly, instead of the finicky flickering of the C01S at the border between off and on states (does anyone else have this with their C01S?).
The spill and hotspot are wider on the i1R2 compared to the C01S, making it really great for general illumination. The color temperature is also colder and colors don’t look as nice. It’s also brighter.
Compared to the original i1R (based on images), the head/body split on the i1R 2 is more uneven (~75/25 vs ~55/45) making it a little trickier to grip the back for one-handed operation. The tradeoff is a nice captive head. I’m not sure if the head can actually come off.
The size and weight are very nice for a keychain light. The diameter is noticeably larger in my hand than the C01S, and I wish this weren’t the case.
Overall I like it in nearly every aspect, but the color temperature and CRI of the C01S are more pleasant.
Hey, so I got one of these i1R 2 eos’ from Olight on black friday when they did the “free, but you pay shipping” deal for old customers and it immediately went on to my keys.
So far very happy with this. Previously I was using their i3E eos and it was my favorite key chain light. However i like the charging ability of the new one. also the two modes are great. it’s not a double twist. you just twist and it comes on low and if you keep twisting it goes high. also it stays together when open for charging, so you don’t have a tiny piece floating around on a desk or floor waiting to get lost under something.
One thing. I have a little trouble getting my charger cable in. like the cable is too big, but it does charge. normally I have too many cables and don’t want more, but this time I wish they sent one.
Noticeably worse than the SST-20, though more pleasant than my Sipik SK68. That and the non-replaceable battery are the biggest weaknesses. Otherwise it’s very nice.
Does anyone know how to test for LVP?
Without disassembling I can’t measure voltage, so I have kept the light on to see if it turns off by itself. Right now the light is so weak that it must be sub-lumen, as it is useless for anything except in pitch black. I can comfortably look straight at the LED. I can’t see colors with that brightness. It’s strange when red looks black. Still, it’s amazing what even a tiny amount of light can do, definitely better than nothing.
Yes, just got mine. I had interpreted my i1R EOS as leaning cool white. This i1R2 EOS is most definitely cool white. Larger TIR optic. I can see the 130 to 150 lumens jump. It’s nominal. Frankly, I just assume they keep 130 lumens and extend runtime more.
Btw, just be aware that when you keep on your key chain, the lower body grip area (fluted lines) will lose lots of anodizing from rubbing against metal keys. When I get a chance I’ll take a comparative photo to show it.
I jumped on the “free but must pay shipping” deal and received my light yesterday, Looks nicely made. Bright enough for its intended use and is pretty easy to operate with one hand. I had to practice a bit, but it’s a solid design.
My only concern is the non-replaceable battery. Kinda stinks if it’s going to be useless one day. I dislike disposable products.
I did some poking around and on the Olight product spec page, there’s a few pics of the battery and both sides of the charging board. I couldn’t see the brand name of the battery though or the size.
as for being disposable? even if it dies completely one day I have to assume it has more than enough cycles in it to get me to another even better light sometime down the road. I’ll use the hell out of it and gladly give them as gifts.
I look at it this way — the cost of the light is far cheaper than the effort to replace the battery. It is disposable… unless someone wants to have a practice run at soldering with it. Would be curious to see if anyone has tried modifying.
these little 10180 lights are pretty generic
you can buy replacement 10180 cells that are usually unprotected
Klarus sells a protected version
I dont own the Olight version, and its cool the head is captive, but Im confident it can be removed so you could replace the battery
there is NO LVP built into these lights
you Can buy batteries w LVP
> Does anyone know the CRI on both of these lights?
they are low CRI, that means about 70CRI Ra, with negative CRI R9 (red spectrum)
IF they were High CRI, it would be mentioned in the marketing material
Olight only makes One High CRI light I can think of, and it has terrible tint rainbow (xp-g3 S1 Mini)
