✌ FREEME- ASTROLUX MF01 Mini 7*SST20 CRI95 26650 ANDÚRIL Flashlight Group Buy - $45.99
40mm x 1.9mm ucl lens fits the mf01 mini?
https://budgetlightforum.com/t/-/58386
Sent. [quote=trailhunter] Anyone know of a coupon code I could use for the mini copper? [/quote]
Does anyone know how to turn the secondary brighter? On mine they are so dim I can barely see that they are on. I took the bezel off and looked at the pots but I don’t see how to adjust them, looks like a cage covers them preventing them from being adjusted.
Set them to High in the software settings first. Seven fast clicks from Off will cycle them Off, Low, High, Blinking. If the High setting is not bright enough, then you can try turning the pots. You need a small screwdriver.
Here is a pic of the MF01S.
There is no cage. If yours has a cage, can you post a picture?
Got one from banggood but it didn’t include a printed user manual. What should I do to get one, anyone in the USA can help me?
Digital copy might be more useful. Save to your smartphone for quick reference?
Also, it looks like there are secondary green LEDs but they don’t work (MF01 Mini - adjustment screw does nothing except for blue and magenta). Is this normal as the pictures show three colors?
The green only light up above 3.9 volts.
The 4th color is red, but they only turn on below 3.3v.
Unfortunately, green never turns on, even at full charge and doing a battery check test (triple click). Thank you for confirming the normal behavior; I will contact banggood about this.
Anyone have the silver color? If so, is the bezel really a darker gray (as pictured) than all the other stainless steel bezels?
It seems most don’t like the green color and just turn it way down. You actually want the green. Kinda odd. Lol
Compared to the womanly pink ones yeah (I’ll turn those down instead of green)… Plus it’s only when it is off and won’t affect the main light anyhow. To each his own (Forest Green > Girly Pink any day, my how times have changed)…
Interested
Asked before, but didn’t get an answer. Did anyone happen to find a holster that will fit this light?
Although it doesnt go all the way to the bottom, it goes far enough (pretty close) and works:
https://www.ebay.com/itm/Belt-Clip-Flashlight-Holster-Pouch-for-Surefire-Ultrafire-Tactical-LED-Torch/391434313209?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Also been using this which is a pretty good fit although it can slide a little bit, but some tennis racket tape around the battery tube would make it 100% tight:
https://www.ebay.com/itm/Tactical-Quick-pull-Buckle-Hook-Handcuffs-Belt-Strap-for-Key-Black/143433961351?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
You can’t go wrong with the first one, it works; but it would be nicer if it was a bit shorter for a perfect fit. Second option is probably better if you go with some thin racket grip tape as I mentioned.
I use the convoy holster.
Tight fit but it works
I’ve had this flashlight for a month and can give a short review.
The light has a high output even in the SST20 4000K version. It’s not very throwy, more of a floody but dut to ots hight output can shine far away even with its floody beam.
There are some thermal issues with this light but if you are not fixating on them you may even not notice. There is a mod prepared by “man of light” to fix them. Also “lexel” contacted manufacturers so maybe they will implement it in future runs.
The voltage measurement may not be 100% correct but you can flash the firmware to correct it.
The flashlight body is robust and if you drop it it will most likely fall on the ss bezel or bottom. I dropped it a few time and it still works great. Its bit scratched and beaten up but didnt fail on me.
I only used the USB C charger once and it worked very well and acceptably fast.
Considering the price I paid for it, there are few bugs they should fix in next versions, but all in all a great flashlight, I EDC it. Currently my favourite dog walking, poop picking flashlight.
This is a tight fit but works well.
here
This light deserves a better home.
