āHoney Iām going out to the shop, shouldnāt take but a few minutes!ā ā¦ 3 hours later, dirty and bedraggled, I stagger in with a grin on my face.
Or in this case, 4 days later and some 26 hours of tedious work laterā¦
Not much of a mod, but really tested my patience! I stacked a second current sense resistor on my S12 driver. Could not find the right physical size so had to go one bigger. The first attempt resulted in assembly and current check, still at 6 amps. Took it all apart and worked on the stack a little more and now I get 9.1 amps!!! The Nichia 219Cās at 4000k now look much better and it really does not generate that much more heat.
I really like this light, could almost bring myself to test EDC it.
It really is super compact and not quite as floody as one would expect. I really do like it, just would like ramping firmware. Does not need a side e-switch, IMHO.
*the screws but also the threads in this light are made of cheese, use a very well fitting screwdriver (I had to drill one screw out, so now the head hangs on 3 screws instead of 4, which is no problem at all btw)
*there are no o-rings anywhere, just some grease in the fittings.
*the 3000K SST-20 works very nice in this light, but I regret the White Flat, it does not throw all that better than main led (it is in place of the UV led so it may get less current) and the beam is ringy.
*the ledboard fits over the edge of the driver board, but is also fixed in place with two pins that are soldered inside two small holes in the ledboard.
*it is a bit tiny in there , at these times I admire tterevās mods even more.
Made a base for my LT1. Used a salvaged T&B brass floor box cover. The casting is not great and it has stress marks in the brass, so likely will not get a high polish. I need to make the black spacer ring again, not roundā¦ could not find my dividers. But, I like it. It will not tip now and looks nice on the headboard.
Put a SBT90.2 in a convoy L2. Man, it is a big beautiful emitter.
I changed the FET to a sir800dp. With an aspire 26650 and clamp meter I measured about 22A. With a 10mOhm shunt to simulate the resistance of the tailswitch I measured 20-21A. With the light assembled I measured 280kcd at about 5s after turn on. The beam looks just a tiny bit smaller than an EE X6 with dedomed SST40.
This host has seen several emitter combinations. Before this I had a spacer and 3 EE X6 reflectors. With 3 2mm WFs it pulled about 19A and did 290kcd. With my ceiling bounce calibration it did 3600 lumens. The 3x 2mm WF is a pretty potent setup. Before that I had 3 sliced SST40s that pulled 18A and did 215kcd and 4500 lumens. Now with the SBT90.2 it does 280kcd and 4050 lumens. Take these lumen measurements with a grain of salt but they should be consistent for these lights.
Cool good too see the Lux and Output numbersā¦ the L2 has a smaller reflector than the FT03 so Iām not that low on my Lux numbersā¦ try a 30T in it if you have one, should boost it a bit.
. Here are the 3 FT03 I haveā¦ L/R FT03/SBT-90.2ā¦. FT03clean de-domed SST-40ā¦. FT03/NW (dome on) SST-40 ā¦ā¦ā¦all 3 set to about 80-85lms.
. Just to compare the size of the spot in the same light with these different emittersā¦
