That would be awesome with the 2300K high CRI emitters. Most warm white LED Christmas lights I see are too pale green-ish and too high CCT to match the old low voltage incan’s.
The fastest shipping of anyone I’ve purchased from. Get these before they’re gone. Twice I’ve bought small orders and Andy sends them nearly immediately. Thanks man.
I’ve got 4000k SST-20s and I really don’t like the tint. Just curious what method you used to reflow the LEDs and what you think the lumen loss might be? I reflow my LEDs on a skillet on the stove on low heat but I read you used hot air?
I use such lights to light up my tent. I’ve been looking for a high CRI variant with no luck.
I doubt it exists but if you see one I would love to see that as well.
No. I didn’t used the hotair. In a separate thread I wrote that it stopped working in the middle of soldering. The heater burned down. I had to use an electric stove and a solid aluminum heat sink so as not to put the mcpcb directly on the heating element.
In addition, I had to reflow several times, because 219b always move to the side. It is a miracle that leds survived it.
I don’t know if this is normal. I always have a problem with these leds.
LED centers itself. But when I tap the LED to get rid of excess tin then it shifts to the side. When I try to move it to the center it runs to the other edge.
I suspect that the reason is a smaller anode and cathode pad on Nichia LEDs. I don’t have such a problem with other LEDs.
Hmm that’s strange. I’ve never had this issue with centering. I normally use the blunt end of a toothpick and gently tap the center of the dome to remove excess solder.
Not a huge difference but the correct diagram for my emitters is below:
