Review New Manker E02 (AAA powered)
27 posts / 0 new
robo819
robo819's picture
Last seen: 3 weeks 3 days ago
This is the new Manker E02 sent to me for review from Manker and no other compensation other than the light in return for my review.
The E02 is a 90 degree head , AAA powered light (also NiMH can be used) and has the appearance of many of the headlamps that are on the market now with the 90 head. It would make a good candidate for a small headband , if Manker so took the notion to make one for this light , but that is just my opinion.
I received the black anodized version of this light for my review and they also will be making a grey colored one as far as I know. The anodizing on the sample I recieved appears to be very well done. I have not found any bare spots or thin spots on the sample I received (other than where I banged it on a metal post accidently , I made a scuff mark but it did not go through the finish) The finish is a nice looking Flat or Matte finish and the knurling is also well done on the light. The threads are square cut and very well cut and they were lightly lubed upon receipt.
My sample came with the Lanyard , 2 extra O-rings and even an extra clip in the box , which was a nice surprise.
The overall size is 73 mm long , 15.75 mm in the middle of the tube and 18 mm at the widest part of the head.
Both ends of the tube threads are anodized , so manual lockout is possible from either end , as well as the electronic lock out feature in the UI.
The end of the tailcap has a fairly strong magnet on it so the light can be used for a lamp or work light if attached to a metal surface. The stainless clip can be used on either end of the light and it seems to be a fairly sturdy built clip and is pretty stiff , so it should stay in place well.
The E02 sample I received has the XP-G3 (cool white) emitter in it , but as I understand they should also be available with the Nichia 219C when Manker gets things rolling. The OP reflector and AR coated lens makes for a pretty smooth , floody beam and I was impressed with the amount of output that is coming out of this little AAA sized light in Turbo. There are 2 mode groups to choose from and when you stay in the lower 3 modes you have L / M / H …..or , Moon / L / H (depending on mode group) and then the next click will reverse the order back down with each click , or you can double click to go into Turbo from any mode (including off) and from there each click can take you to the strobe , SOS , or beacon mode. There is also mode memory that will get you back to the last used mode , including any of the blinky modes , if you choose to turn the light off in one of those modes. There is a 3 minute Turbo timed step down , which at that time takes the light to the High setting. (although the light did not get to hot at the 3 minute mark) One thing I really like about the E02 UI , is that you can set the Moonlight (or firefly) mode , from what they call the “Engineering mode” to a number of different levels (16 if I counted right) , from barely visible to around 2 or 3 lumens , which is great because everyone can choose the level of light they want with this feature for the Moon Mode. (I didn’t measure output when I did this part)
The overall the build quality of the E02 is very good and I really do not have any complaints with this little light , as I like it alot.
NOTE: I used a Rayovac 600mAh NiMH cell for my testing. I do not have any Eneloops in the AAA size (just yet) , but I feel they would give a better run time than what I used for my test , as my AA size Eneloop pro always perform better than the Rayovac NiMH I have in that size.
The testing I did on this light is listed in the charts below……….
The User interface Chart………..
Again I will say…….my cheap video camera does not show as true to life as the still shots in the video portion as to what I actually see.
There is a couple of shots comparing the Thrunite T01 with the E02 at 10 and 25 yards…..the very last picture of the Thrunite is labeled 10 yards but should be labeled 25 yards.
For those who do not want to watch the whole video the stills of the light and beamshots start at 6:06 in the time line and the live outside footage starts at 9:57 of the time line.
Video with listed specs below that…………
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 05/12/2017 - 19:27
DB Custom
DB Custom's picture
Last seen: 5 days 1 hour ago
Nice work Robo, neat little light that could come in handy in a lot of scenario’s. Not sure how they get 200 lumens from a boosted NiMH AAA cell but that’s a decent amount of light coming from such a small pocketable light. The magnetic attachment will probably make it useful in a LOT of ways!
Gonna have to look this one up, should make a nice gift or 3… Wink
sbslider
sbslider's picture
Last seen: 1 day 4 hours ago
Nice review, especially appreciate the tailcap current. Looking forward to this light being released, I can see picking it up. As far as AAA goes, this does it all. I like being able to start in moonlight mode OR a normal mode if desired with one click. Also tailoring the moonlight mode sounds fun, but I am guessing it is not super practical.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
mrmatt
mrmatt's picture
Last seen: 8 months 3 weeks ago
AAA powered lights are my weakness. I’ll wait to see what the headband looks like though, if it’s a solid rubber type (eg armytek, xtar) and no plastic parts that might break I think it will be a great lightweight option. Only other one I’m aware of is the Fenix HL10
robo819
robo819's picture
Thanks Dale…yes it was a surprise to me also to see how much light comes out of this little thing.
“Nice review, especially appreciate the tailcap current. Looking forward to this light being released, I can see picking it up. As far as AAA goes, this does it all. I like being able to start in moonlight mode OR a normal mode if desired with one click. Also tailoring the moonlight mode sounds fun, but I am guessing it is not super practical.”
Thanks Sbslider…No problems taking the current I try to get a tail current any time I can with the lights.
The moonlight mode stays set after you set it one time also , really not that big of a deal in the end.
AAA powered lights are my weakness. I’ll wait to see what the headband looks like though, if it’s a solid rubber type (eg armytek, xtar) and no plastic parts that might break I think it will be a great lightweight option. Only other one I’m aware of is the Fenix HL10”
I am with you on the headband Mrmatt……maybe they will make a nice one for this little light.
sbslider
sbslider's picture
I guess what I meant by my comment is I am not sure how much of a practical difference it would make to be able to tailor the moonlight mode. Although I think I did see in another review that it is a pretty wide range of adjustment, even to slightly above 1 lumen, so perhaps this could be handy if you knew you needed a bit more umph in some situation. I could see that being handy for camping, likely a bit more output from a moonlight mode would be good in the outdoors compared to inside.
Jerommel
Jerommel's picture
Last seen: 2 weeks 14 hours ago
Can’t wait for these to become available.
robo819
robo819's picture
You are right the moon mode does have a wide range and I have now carefully counted each step and found that there are 21 levels instead of the original 16 I had stated.
I have seen so many times where a number of people either complain about a moon or firefly mode being too bright or too dim on a given light for their liking. Some like a super low moon while others like a little brighter moon mode , I am sure according to their own eyes and how sensitive they are , how good the individuals vision is etc…..
That was what makes me like the ability to set the moon mode to each persons desired liking , as then there is no complaints and you have your own perfect moon level for your eyes once you set it where you like it for yourself.
Again this is a personal observation and the adjustable moon mode may or may not be liked by others as well as it is by myself.
sbslider
sbslider's picture
Agree with your assessment. I had not thought of it that way.
saypat
saypat's picture
Last seen: 2 hours 12 min ago
very nice review, Manker got a good deal in this transaction Smile
terrific AAA light, will have to pick one up when available.
thank you robo…
robo819
robo819's picture
thank you robo…
Thanks SP…….I haven’t seen a price yet , but I think it should be announced soon , unless it has been already and I just haven’t seen it.
qandeel
Last seen: 8 hours 20 min ago
They said $19.95 in post #15 of Budda’s review thread of this light.
http://budgetlightforum.com/node/54307
Mankerlight wrote:
price $19.95,  do you like?
 عُمَانْ
robo819
robo819's picture
Thanks for the info….. I never saw the price.
raynman
Manker is selling them on eBay for $19.95 with free shipping (to me, here in the US, anyway) from China via e-packet
Manker E02 on eBay
looks like a nice little light.
sbslider
sbslider's picture
I have looked at a few of these review, and each shows the user interface sheet screenshot. Some of those user interface sheets mention dragon breath, and others do not. How I saw how to get into that mode was to turn the light off and continue holding down the switch will get the light into dragon breath mode. In this mode the there is a light behind the switch that pulsates slowly.
Does your light have the dragon breath feature?
robo819
robo819's picture
Hey SB…..
If mine has that feature I am unable to find it on the user guide or the light either one.
sbslider
sbslider's picture
Ok, thank you for trying.
Beachlogger
Last seen: 7 months 6 hours ago
So there is a headband planned for this light?
robo819
robo819's picture
I believe Manker is thinking about the option on the headband.
Jerommel
Jerommel's picture
Hmm.. I wonder how effective this will be as a headlamp.
It’s probably too focussed for close up things and not bright enough for distance.
It’s a ‘must have’ though, i ordered a grey one with XP-G3.
robo819
robo819's picture
Jerommel wrote:
Hmm.. I wonder how effective this will be as a headlamp. It’s probably too focussed for close up things and not bright enough for distance. It’s a ‘must have’ though, i ordered a grey one with XP-G3.
It isn’t bad for close up work and It does well out to around 35 or 40 yards , it is a more floody beam though not throwy.
Mankerlight
Mankerlight's picture
Last seen: 3 weeks 2 hours ago
Clearance Sale Now!! E02,E02H and E03H 50% OFF
Mail:sales@mankerlight.com
Web: www.mankerlight.com
Welcome to join Mankerlight Group in Facebook.
TexasToasted
TexasToasted's picture
Last seen: 4 weeks 15 hours ago
Purchase from Manker at your own risk. Manker’s 5 year free replacement warranty is a scam. HKEquipment sent me a defective U23. They wanted me to ship the light back to Hong Kong at my own expense, even thought I ordered from their US warehouse. I contacted Manker directly and they refused to replace it or even send me a replacement driver. Manker said I had to pay to ship it back.
Muto
Last seen: 41 min 8 sec ago
Hell hath no fury like that of a customer scorned.
Congrat’s on 1000 posts as well!
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
Well I don’t know if I’m coming or going
If it’s them or me
Oh, but one things for certain
Willie Nelson only smokes the killer weed
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
TexasToasted
Maybe I should post my gripe in every one of the threads Manker has spammed today Big Smile
WalkIntoTheLight
Last seen: 4 months 1 week ago
If you paid with Paypal, they have a feature where Paypal will pay for the shipping at no cost to you. I’ve never used it, but the details say you just need to make the postal claim and then send them proof you mailed it. Or I guess you could try to make a claim that you received damaged goods, though they’ll probably just say you have to mail it back to get your refund.
In any case, I wouldn’t want a replacement or repair. Try to get your money back.
hIKARInoob
hIKARInoob's picture
Last seen: 1 month 4 weeks ago
What if everyone with Mankerbeef (yes, it’s an official word) did the same… Big Smile
