✌ FREEME- ASTROLUX MF01 Mini 7*SST20 CRI95 26650 ANDÚRIL Flashlight Group Buy - $45.99
Interested
Asked before, but didn’t get an answer. Did anyone happen to find a holster that will fit this light?
Although it doesnt go all the way to the bottom, it goes far enough (pretty close) and works:
https://www.ebay.com/itm/Belt-Clip-Flashlight-Holster-Pouch-for-Surefire-Ultrafire-Tactical-LED-Torch/391434313209?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Also been using this which is a pretty good fit although it can slide a little bit, but some tennis racket tape around the battery tube would make it 100% tight:
https://www.ebay.com/itm/Tactical-Quick-pull-Buckle-Hook-Handcuffs-Belt-Strap-for-Key-Black/143433961351?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
You can’t go wrong with the first one, it works; but it would be nicer if it was a bit shorter for a perfect fit. Second option is probably better if you go with some thin racket grip tape as I mentioned.
I use the convoy holster.
Tight fit but it works
I’ve had this flashlight for a month and can give a short review.
The light has a high output even in the SST20 4000K version. It’s not very throwy, more of a floody but dut to ots hight output can shine far away even with its floody beam.
There are some thermal issues with this light but if you are not fixating on them you may even not notice. There is a mod prepared by “man of light” to fix them. Also “lexel” contacted manufacturers so maybe they will implement it in future runs.
The voltage measurement may not be 100% correct but you can flash the firmware to correct it.
The flashlight body is robust and if you drop it it will most likely fall on the ss bezel or bottom. I dropped it a few time and it still works great. Its bit scratched and beaten up but didnt fail on me.
I only used the USB C charger once and it worked very well and acceptably fast.
Considering the price I paid for it, there are few bugs they should fix in next versions, but all in all a great flashlight, I EDC it. Currently my favourite dog walking, poop picking flashlight.
This is a tight fit but works well.
here
This light deserves a better home.
When i charge for the first time my mini with usb the green not turns on , after that i discharge and charge the battery with a Charger and Green turn on.
Agreed. What about a holster designed by Astrolux? I think they have sold enough of the MF01 mini that it is time for a dedicated bag.
This is normal. The charger only turns on below a certain voltage. Maybe 4.0 volts?
Agreed, id pick up a few right off the bat. The quality for the MF01S and ft03 ones were great.
After having the MF01S, I just had to have a Mini. Just picked one up in gunmetal. Thanks for the group buy, freeme!
Goy my MF01 mini yesterday in gunmetal grey 5000k… feels great its very bright on turbo, alot more then my ff e07 and d4s emisar. I just wish the aux leds on high were brighter :frowning: I thought first i was on low but then realized they arent that bright on high compared to my ff e07 or emisar… i know u can manually turn them up with a screwdriver but im not gonna bother with that… should have been possible adjusted with low and high mode in settings instead imo hen have to screw up the lens… but still a great light finish is good and the neutral tint looks good.
i like how the aux leds change color depending on battery voltage.
The mf01 mini has become my favorite in the bag light which used to be my D4s. Did some tint mixing on mine to get my new favorite CCT 3500K and turned out lovely. Very close to 3500K e21A.
mix of 3x4000K (stock), 3x3000K and 1x3500K (middle)
L-R: MF01 mini (3500K mixed SST20s), Jaxman E1 (e21A 3500K), Rofis R1 (e21A 5000K)
I have two of these: https://www.banggood.com/Astrolux-Flashlight-Protected-Bag-Holster-For-Astrolux-S41S41SS42S42S-Lumintop-FW3A-Flashlight-p-1089597.html?rmmds=myorder&cur_warehouse=CN
Fits perfect in fireflies E07 and MF01 mini too.Good quality.
I prefer lower AUX output to mimic tritium effect.
Have forgotten about this one. Will bring msg BG in the morning ASAP.
I have noticed that the small Sofirn holster is a nice fit for the MF01 mini. It is elastic and thus fits also 26650 flashlights.
€ 3,88 and worst quality than Astrolux Astrolux holster costs $1.94 :wink:
https://imgur.com/NiCz1Gm
[img]https://i.imgur.com/NiCz1Gm.jpg[/
[img]https://i.imgur.com/NiCz1Gm.jpg[/img][img]https://i.imgur.com/NiCz1Gm.jpg[/img]
On the new Sofirn website sofirnlight.com they are pretty cheap, 2.99$ for two bags with free shipping above 19$.
I would say the quality is pretty decent and it is slightly bigger than the Astrolux. Of course, the Astrolux is more compact.
