That would work, you could do a similar circuit to the yellow work lamps that take 18650 and AA, they have a series of diodes to prevent charging of the AA.
Also thinking plastic should be considered due weight considerations, and also cost. Assuming reasonable durability, but the lighter it is the less force acting on it to cause damage.[/quote
I think going composite (plastic or something else) is the way to go. The cost of mold-making might make the project unprofitable however. I would think 5000 units or more would have to be sold to break out on it. Personally, I would not carry a metal flashlight on a backpack venture. As Colin Fletcher once said, “Take care of the ounces and the pounds will take care of themselves.” I cut toothbrushes in half and stuff like that. Nothing metal in or on my pack is how I go, if possible. I’m keen on the aaa batteries as a power option, or aa would be fine too. I can’t imagine carrying power bricks in a backpack.
As I mentioned earlier, I’ll buy anything with the BLF monicker because I like the looks and function of everything I’ve seen. If the mini lantern is too heavy for me, then I’ll surely find a use for it elsewhere. So carry on dbsar, I’m sure it will be cool. Check me for one at least.
I have thought that’s applicable to both LT1v2 and LT1 Micro.
It would be useful to make battery-less USB-powered work one of primary use modes.
Why?
LT1 already works great as a night lamp next to my bed but only as long as it has a cell inside - otherwise there’s coil whine and annoying red/green button. I can use it with a cell but would rather avoid the extra wear I put on the cell.
For portable applications I would often prefer a lantern to be as compact and lightweight as possible. And when I have a powerbank with me (which happens almost always when I’m camping) ditching the battery tube would save a lot of bulk.
Regarding coil whine in the LT1, has anyone tried sticking a big capacitor or two in an 18650-sized shell? It might be possible to replicate the cell’s role as an energy buffer in USB-powered operation without needing the full capacity of an actual cell.
Update: 01/03/2020) i am awaiting for a couple potential hosts bases from Barry & Sofirn shipped out to me a couple weeks back, once i receive them i can work on the design & testing for the micro/Mini LT1.
