Removed the copper and found the thermal paste barely spreaded out. It seems helped a bit but I think there is much to improve. The gap was too big above the 7135 tops for a grease.
So I tried thermal silicone blocks this time. Cut them to size and the copper thing spreaded them out.
Then I cutted very thin layers to press thm between head side and copper spacer side:
These two graphs with 35 click ramp max setting so 1367 lumens at start. The left was just thermal grease on 7135 tops. The right was the silicone stucked version test same settings. Much smaller drop in beggining and no drop after 9 minutes. Needed to interrupt test because we had a coffee break at work
There is nothing between driver ground edge and copper spacer so maybe there is a tiny bit to improve that first little drop but it is much better.
Further tests coming weekend.
The first run was not so good because I didn’t followed instructions but better than plastic. Second is almost perfect but I still doesn’t put everywher thermal halping material where it needed. So the copper thing is good just need to follow the instructions precisely. It is a bit hard to put thermal compound to the copper side but it is doable.
@Zozz, thanks for explanation and the latest results :+1:
The idea to use thermal silicone pad is not bad, nice pics, thanks for the work.
It’s really important to spread the thermal compound on the defined surfaces, like shown in the description in post #1 and on this pic below.
Before mounting it should look like this, but here is a bit too much thermal compound paste spread on in this pic, just to show where it should be.
After mounting, use a cotton pad to clean up excess residues.
This gap is around 0,1 and 0,2 mm after mounting the copper heatsink plate. It depends on manufacturing tolerances and tolerances of the components (7135) and also of the pcb and soldering process. Designing this gap closer is possible, but it brings some risks. It may be possible that another production batch of driver pcb’s will not fit or there will be no gap. Tolerances differs often on pcb’s.
Therefore the idea to use thermal silicone pad is not bad, but in most cases you will achieve better thermal conductivity with grease/paste.
As you said you can’t design it to get too close to 7135 top because if it has a bit more solder under you can possibly break them tightening the copper. You need a bit of clearance. That is why I tried silicone. It works like a gum and reach the 7135 sides too because of the pressure. So more contact surface to get off the heat. I maybe only use paste on that contact ring on driver. I think I will disassemble it a few times to get best results.
I’ve always learned that thermal grease is only to fill in the tiniest of pores and scratches between two metals. You guys are killing me with just glooping it all over and trying to fill in these giant gaps. Lol
Recently, I needed to buy Arctic Thermal Pad and it works quite well in one flashlight. Cutting the right pieces is probably a better solution than dirtying everything around with paste.
Thermal pads have worse conductivity than paste…but their big advantage is that they are solid. Paste may move around and leave you air gaps just where you don’t want it.
I think that’s only true when both are used properly. Since we are not using the paste properly I think we have to throw this whole statement out.
BTW, are these thermal pads like the ones used for cpu’s? One use only, once separated you have to throw it away and use fresh pads. Plus you have to get the pad really hot in order for it to conform to the proper shape. Maybe newer style pads are designed differently?
I don’t know where they put them in exactly.
Don’t know maybe easier to apply thermal pads in exact same amount than paste.
Didn’t bought them.
I work in an automotive electronics manufacturing company where we produce so many type of electronics for cars. B&O is one of our buyers. We make electronics also for Harman Kardon, Delphi, Valeo, Aptiv, Honda, Porsche, Mercedes… But I don’t work at that area just asked collegues for thermal pads and they got me a few.
many devices use thermal pads now a days in production, its more consistent in application, and is easier and cleaner to work with.
in most cases that outweighs the minor differences in thermal conductivity, especially in production gear that has a large tolerance on the thermal characteristics.
i would wonder however if there would be manufacturing tolerances on this light that are so great that there would be measurable differences in the clearance between the copper sink and the chips themselves.
it would probably not be known until a large number of devices have had the copper sink in them.
What thermal paste did you use in your experiments man of ligjt? You obviously worked with heatsinks a lot, what paste (brand type) do you think would be best for this application? I could use professional opinion.
