Just curious, who have used their first bought LT1 lantern now in a power outage, on camping, or any emergency needing a long-running, great tint, high CRI, 360-degree light source where no electricity is available?
I have used mine every night since receiving. Mostly on level 2. I somehow made it in the 1st shipment even though I was a little past 500 on the list.
So somewhere around a month of use and charged it only twice if remembering correctly.
Been living in my van since last divorce. Will buy another place some day but it’s a great feeling for now not having all the bill’s and upkeep to pay for.
Loving the LT1 adjustable tint and ease of charging. Deciding to order my others now or wait for other color and upgraded firmware later.
With no batteries connected the buck converter on mine makes a horrible screechy noise on input voltages higher than 5V. On stepped level 2/5 it makes it at 5V as well. With batteries in and charging, there’s no noise.
Doesn’t really work for running from a 12V source without batteries then.
With a 12V input and the batteries disconnected my first batch unit does the same. Horrible squealing. So it’s probably not a bad inductor.
Wasn’t the ability to run without the batteries attached “discovered” as an accidental feature? So if this use case wasn’t designed for, it’s not really a concern for me.
It does work happily at 5V like this with no noise, so I’m considering it a bonus feature. This lantern does everything I’ve wanted for a long time. DBSAR, Lexel, TK and the team really knocked it out of the park on this one.
I just flashed the anduril.2019-11-29b.blf-lantern.hex on my unit, because it went into kernel panic strobe mode more often than I cared for, and ToyKeeper said this should improve that.
But I used the Emisar pogo pin while holding another wire for the reset pin, and hitting enter on AVRDude with my third hand. Needless to say that was less than fun.
Does anyone sell the HQ Universal Driver Programming Key already assembled? I don’t have a reflow oven and soldering the pogo pins to the PCB is not my kind of fun either.
I’ve googled the tar out of this and can’t find a US source for any pre-assembled Lexel driver compatible pogo key. TIA for any help!
Yes, indeed the ability to run with no batteries was an accidental, but great usable feature. :+1: The inductor begins to oscillate at high audible frequencies past 6 volts, but at the standard USB 5-volt input its silent. a low cost 12 volt to 5-volt USB adapter fixes the noise issue for anyone wanting to run it directly from 12 volts. I have test run the first production unit i bought for 5 days/24 hours non-stop on mode-3 of the stepped settings using a 5 volt USB wall adapter. it stayed quiet as a mouse.
I have a first batch lantern. I get the inductor whine when I have tried it connected to power supply without batteries. Its completely silent on battery power though. I use it every night as a lamp alternative in my office. Works flawlessly. I have charged it fully one (1) time since I received it. Really is a fuel miser in my experience. Can’t thank the team enough! I was on the list for two lanterns. Getting my second one now with code sent by Sofirn. Awesome lanterns!
Watch out with buying multiple lanterns with one code as you only get discount for first lantern. I bought two and only had the first one at group buy price. This happen to anyone else?
Yes. It happened to me as well.
I messaged Sofirn and explained that and he said it was an error with their code. He has sent me a new code.
My advice is to message Sofirn back directly.
I’ve suspected for quite a while that 600 was probably too high. It’s pretty common for amc7135-based drivers to get around 100 lm/W when using medium-CRI LEDs like XP-L HI, and this efficiency goes down when using high-CRI LEDs.
If I understand correctly, my prototype was made before the correct LEDs were sourced, and it probably gets near that common 100 lm/W level. Using some quick napkin math, this would make it…
350 mA * 5 * 3.6 V * 95 lm/W = 598 lm
… which is pretty close to the estimated value of 600 lm.
But with high-CRI LEDs it should be lower. Let’s say 75 lm/W…
350 mA * 5 * 3.6 V * 75 lm/W = 472 lm
… and that’s pretty close to maukka’s measurement of 463 lm.
I think the output was going to be increased by using a somewhat less-opaque diffuser, but for some reason the factory went with a diffuser which was more white and less clear. So the beam is really smooth, but it reduces the total output a bit.
Efficiency could be increased by using a boost or buck driver instead of a linear driver, but that wasn’t within the scope of the project. It’s mostly just an idea for next time, if there is a next time.
Could someone point me to the driver schematic please ? I am sure i have seen it somewhere (but maybe that wasn't the latest version) but can't find it anymore
Probably, depends on the inductor used.
I think only the ‘open type’ can be glued or potted to stop coil wine. The ‘box’ one’s probably not.
However it’s worth a try ;).
Just received my lantern! Ordered from amazon.de on november 16 and shipped november 30 according to the tracking details.
Heavier than expected but that’s not a problem for me.
Look and feel is great! Really happy with it. Probably not going to use it in a real camping situation but you will never know :).
The light is nice warm on the warm side, a bit too cold on the cold side. it looks more like 6000K than 5000K to me.
I think I will solder the bridge for all the AMC’s to increase brightness.
