I have 9 lights with 3 different firmware…. :person_facepalming:
I bought 5 brand new drivers from Lumintop, I used 3 so far… 1 of them has the memory option… so far… the other 2 new drivers are waiting to be used… WTF?
Mine flickered, but only on lower settings, same thing on three different bodies, cleaning threads, tightening retaining rings, nothing helped! replaced all 7135s, same thing checked solder joints, did most everything except replacing the mcu. By that time I received a replacement driver which fixed the problem. Definitely exhaust all the possibilities, but in the end you may have similar results.
Has anyone here dropped their FW3C and suffered notable dents? Just curious about the copper alloy, as raw copper is inherently soft, prone to denting.
^ Yep, driver retaining ring and the tail cap — both being loose will end up creating strange behavior. I think that’s pretty much it, though. Easy to correct both! Unfortunately, this light is not turning out to be very user friendly, reliability wise. A number of people I know would be stumped by such a problem and put it down in favor of another light.
How to solve an issue of the FW3A starts to step down automatically almost immediately to a very low brightness level? This happens in both stepped and ramped modes. Many thanks.
It doesn’t have to get hot, it just needs to think it’s hot. It’s internal temperature calibration may be off, that’s why I say it may need to be calibrated. Instructions are in the first post.
Dagnabbit!My FW3A also came with only one of the three available contact points soldered.
With a cold solder joint, so the spring could easily come loose and short out.
Somebody was in a hurry to leave work that day!
And I bought a FW21 anyway. I’ll never learn to wait on reviews.
Has anyone got contact info for the manufacturer? Just TELL the guy who does the soldering how to do it right, please.
I’m not sure if this is a defect or if I’m misunderstanding the Andruil UI.
From OFF, if I long press the button, the light will start at moonlight, but then without me releasing the button, start to ramp up. Then releasing and long pressing again, it will ramp down.
My understanding of the Andruil UI was that I had to short press then long press to ramp up or down. As in, I would depress the button twice. I thought that a single long press from off would go to moonlight and stay in moonlight.
When you hold from OFF…it pauses at moonlight for just a moment…then ramps. Single press from off goes to last brightness level (if memory on). If you release the button during that brief moonlight pause (it is VERY brief) it will stay at moonlight.
If you quick press…it comes on. Then press-hold it will ramp up. Release press-hold it will ramp down.
