Probably still a bad idea.
I think I read somwhere that Vihn has not been able to get the angry blue tint shift with this led? I might be wrong. I’ll try to remember where is saw this.
Linked to a CPF thread recently…
Anyway, strap one to a 30T and I doubt you’ll like it.
That still doesn’t mean direct driving it is a good idea.
It will mainly produce more heat at some point, which is bad for run time and life time of the LED, and cooling can become an issue.
And it’s not as if there aren’t any good FET constant current drivers available.
Convoy has the SST-40 drivers, one does 5000mA and the other does 6000mA, and you can play with the sense resistors if that’s not ideal.
Tests of the Boost HX will determine what’s the best maximum current.
You could look at some data to get an idea what is going on, gives a bit more weight to guesses. If you take the KW CSLPM1-TG as a lower performing Boost HX, I measured its max at 7.5A. Say (this is uncertain of course) that the Boost HX has its max at 10A and the voltage is similar to the KW CSLPM1-TG, at max its voltage is 3.3V. The 30T at 10A is, when it is close to full, 3.9V. That is 0.6V higher, so without any voltage losses in the circuit, the Boost HX would go well over 10A and be seriously overdriven. But place springs, switches, wires and driver circuitry in your electrical path and you get voltage losses, 0.6V is easily lost at 10+ amps.
So, with some assumptions about the Boost HX performance, I think that you can overdrive it but it is a bit of a challenge: the best battery and a low-resistance electrical path.
Oh, that’s more current than i anticipated.
But, i take it you mean 10 Amperes (7.5 A for the KW CSLPM1-TG) is the absolute maximum, and probably only a few % more output than on something like 8 Amperes (say 6 A for the KW CSLPM1-TG)?
But you know i like my LEDs running constant current regulated and the electrical path optimized
I really like FET diy Djozz style driver(nanjg AK 47 one). This is the thread about mentioned driver: comfychair-inspired quick+cheap+lazy single-sided 17DD FET-driver (poor man's nanjg92)
I produced and potted over 200 of them. Only few failed because of mine soldering mistake so I would say after several years that they have almost 0 failure rate!
I would like that Djozze reinvents mentioned nanjg AK 47 FET Djozz driver but this time with some kind of added resistance so we can safely run that little osrams… Pretty Please Djozz ?
So you want DD with resistance, but not constant current with much less resistance, like the LD25 or the SST-40 Convoy drivers or the LD4 from Led4power.
So you prefer to only have full output with a fully charged cell = for a short while.
That doesn’t make sense to me.
Nothing against brand driver manufacturers. I always liked diy stuff…
So yes! It does make sense if FET with added resistance would pull no more than lets say 5A… Plus it is cheap and effective.
But then you’ll have to always have fully charged cells for maximum output.
Why?
It has perfect sense for me. You don’t have to have flashlight pressed on turbo all the time
For example:
Turbo mode 5A, Middle mode 2,5A, low is 1A. You can run it on middle or low mode(saving the battery) and turn turbo for a minute or two when needed.
But even if one wants to run it on turbo only it should not be issue… But FET driver would have to be modded or restricted somehow with added resistance that should not pass 5A.
Since we know that mentioned Osram emitters loose very little on performance and we know how fet driver behaves we could approximately calculate that 4.2-3.3V of battery cell = 5-3.5A current draw on turbo mode which is approximately 30 minutes of turbo mode on 1x18650 Samsung INR 30Q cell by looking HKJ minutes/runtime diagram for Samsung INR30Q cell. Even if it is not in regulation it will still run strongly and one that uses it will not visually notice significant candela/lux intensity change.
I would really like to know how to add and limit resistance on the FET driver. I have very good soldering skills but I can’t do nothing if someone who knows does not show me necessary ingredients of “how to restrict resistance on FET driver”.
The easiest way to reduce current in an FET driver if it is marginally too much is just to reduce the max PWM. This works great for LED’s like the 219C where 100% turbo gives them maybe 25% too much current. Knocking the PWM down to ~75% fixes the issue and works great.
Now if the 100% current is way way too high this might not work of course.
A minute or two is probably what it takes to discharge to 4.0 Volts, and so your current will drop.
It may be better to start with a battery that is already discharged to 3.8 Volts, because that’s where the voltage starts to stay the same for a longer time, just slowly dropping.
But hey, do as you see fit.
I done hundreds of diy FET drivers and some Texas Ace one so I know how they behave. I am looking for permanent solution of restricting FET driver current, and since Djozz mentioned that some kind of resistor can be added to driver circuit I would really like to know what type of resistor and where should I place it in a circuit?
If someone wants to run Osram WF with FET driver just use low current 18650 cell and don’t bypass springs. But however that is not proper and safe solution. Proper solution for FET drivers would be current restriction on FET driver. It should be doable but I don’t know how.
I’m sorry l.i. but although I produced the AK-47 hack back in the days, which was purely an extension of comfychair’s work, I’m not very knowledgable in drivers, not like Texas_Ace or Lexel or DEL or wight.
The idea of putting an extra resistor in this hacked driver is not a really practical one because it would have to be a big one that can handle 5A current.
Maybe if you can guarantee buying a large amount of them, you could ask Simon from Convoy Flashlight to produce a batch of his 5A drivers with high-med-low without memory?
Yes I could. But what should I do with hundreds of AK47C1 drivers(also ordered from Simon) ? I would try to place big resistor on driver cause I pot drivers anyway. Can you suggest me proper resistor for this potential current restriction FET driver mod?
Yes I could. But what should I do with hundreds of AK47C1 drivers(also ordered from Simon) ? :laughing: I would try to place big resistor on driver cause I pot drivers anyway. Can you suggest me proper resistor for this potential current restriction FET driver mod?
The added resistance is going to be in the 0.05 to 0.1 ohm range I think.
I continued this mod by adding some resistance in the same style as I did with my D1S in a post above, by adding a length of nichrome resistance wire. But with the D1 there is not enough room for a length of big wire like I used. I found some nichrome 80 ribbon wire (0.8mm wide, 0.1mm thick) with 4.15 ohms per foot. With its higher resistance and flat shape I figured I could fit some into the tailcap and make electrical contact with the battery tube pressing on it. You can’t solder to it so I n…
Put a white flat 2mm^2 in an Emisar D1S. I wanted to add some resistance to the circuit so I could use the FET driver and limit the current to 6-8A. Switching the springs to high resistance steel would work if you had the right size springs. The battery compartment length is very tight on this light so it would have to be the right spring. I chose to add a separate resistor in the head of the light. I figured I would need to add about 0.1Ohms to limit the current enough with a 30Q cell. The resi…
These are two resistor mods I did for the 2mm WF. Added resistance was about 0.1ohm. For the 1mm WF it should be a bit less.
I wonder…would it be possible to adjust PWM as battery discharges to maintain something closer to constant current?
I think it’s possible. Some discussion here.
I know, first post (here, not anywhere), so what do I know? Maybe not much. And maybe I'm way behind the ball on this thought, but a couple of questions and an idea: How efficient is an led driven by an FET when it's being pulsed, compared to say a linear regulator, let's say in the context of single 18650 XM-L? The FET itself is more efficient but you're driving the LED at high current, for brief pulses. I guess the efficiency for the LED is more aligned with expectations from the ave…
