When the next mode is the one memorized we just call it next mode memory.
Pseudocode:
Next mode memory:
On start
current_mode = stored_mode
stored_mode = current_mode + 1
On time memory:
On start
After x seconds:
Off time memory:
On start
if too_much_time_elapsed
else
current_mode = stored_mode + 1
No memory:
On start
current_mode = first_mode
else
too_much_time_elapsed is when enough time had elapsed to discharge a capacitor or erase/corrupt a known pattern in unpowered ram, depending on the driver having a capacitor or not.
Cheap flashlights have next mode memory because they don’t want to spend a few extra cents in a capacitor+resistor and the memory trick is unknown to them or the time is too short (i.e. unlike the attiny13 they only have DRAM, not SRAM) in their drivers to be useful.
Very nice. I would have been happy if the current 6A SST-40 driver was simply made without memory (I have never understood memory, mode memory makes a flashlight unreliable ) but a biscotti interface is a nice extra
Someone told me somewhere around here that temperature control was too aggressively implemented in SST40 drivers, causing step down very quickly. I myself grabbed a couple drivers to repair a couple builds for family and a friend but haven't done tests. What do you believe?
I have a question regarding LVP on the latest Convoy flashlights (S11, S12, M3, S21A, M21A, L21A, M21B, M21C, M26C). Is there a real LVP or only warning?
echikongen, concerning flashlights with unregulated MOSFET or linear drivers there is no need to worry. A standard blue crystal pump white led imposes a hard limit concerning the absolute minimum voltage which makes it work, this is ≈2.5 V (red emitters are another story). This means it is nearly impossible to over-discharge a li-ion cell with a standard white led as load. This has been tested by myself, feeding a white led with a li-ion cell directly with bare wires. With a driver in between, the over-discharge possibility is even lower.
If you want to really know, test it by yourself by leaving whatever flashlight with MOSFET or linear driver turned on for a few days. After the elapsed time, unload the battery, let it rest a few minutes and measure its no-load voltage with a multimeter. It will hardly be any lower than 2.5 V, if even close.
Concerning flashlights with boost or buck drivers powered with more cells than emitter stages (i.e. a buck driver fed with 2 cells powering a 1S emitter like an XP-L, buck driver fed with 3 cells powering a 2S emitter like an XHP50B, etc.), some sort of low voltage protection or shutdown is a must. In all these cases it usually is implemented unless it is a shoddy driver which Convoy wouldn't use.
So this is the new complaint after “I want a useless moon mode!” ?
I think memory is quite handy, and i bet many more people do too.
My complaint though, is the mode spacing of your drivers, Simon.
I ordered some anyway, but there are low and medium modes missing, big jumps from low to medium, probably because loud voices beg for moon mode…
As if they don’t own any smaller output flashlights already…
Maybe don’t forget most of your buyers (probably) want 4 well spaced usable modes, like 3 - 10 - 30 - 100%
3 modes is enough for up to 1000 Lumen lights.
3% is much too high of a low for camping/backpacking use, which is one demographic target of generic flashlights. It sounds like you need a specialized driver for urban use, but that’s not necessarily the best default driver to sell in their online store.
3% of 10 Watts is 0.3 Watt.
How can that be “much too high”, even in a tent at night?
BTW, i use my lights the most when i’m in rural France, so i know what darkness is.
Besides, when you only have 3 or 4 modes, you basically sacrifice a usable mode when you add a moon mode to it.
But either way, inside a tent, it is preferable to have a wide flood light (like a light bulb) hanging from the ceiling, but that is not always possible.
In a tent a normal reflector light is far from ideal.
I was actually wondering if we were used to different levels of darkness. It is something a lot of people who have access to low population density areas take for granted. Seeing the Milky Way plastered across the sky on a dark night is amazing. But it sounds like we just are accustomed to different methods.
To be fair, we always got by before any flashlights had moonlight mode by blocking the lens with a thumb at night. It was not that big of a deal, but now with the luxury of <2 lumen modes we don’t have to. Now the brightest things I see in camp are overpowered 5mm red LEDs on cheap plastic headlamps. I am only one data point, but I wouldn’t buy a 1000 lumen light that didn’t have the 0.1% mode any more due to the way we use flashlights in the wilderness.
I don’t care about mode memory myself — there are pros and cons — but predictability of modes is important to some people. It would be nice if it was possible to cut a trace on the circuit board to disable the memory.
Okay, i see your point about camping etcetera.
But i have other lights low level usage.
In a tent it’s always a little difficult though.
You need one hand to lean on, and the other hand to move stuff around.
No flat surfaces to tailstand a flashlight on…
Yes, a headlamp would be okay, or a single AAA light you can hold in your mouth, but some wide flood light hanging from the ceiling would be better.
As for memory, well, opinions vary.
I hardly ever switch off in the highest mode anyway.
But when i switch it on, i don’t want a moon mode to skip through.
Aaaaanyway… This is the Convoy thread…
I decided to comment because i decided to buy some drivers from Simon, but most of them are missing a low or mid mode, jumping to or from 10 times the brightness to the next mode…
That just sucks i.m.h.o.
But apparently the solution will be complicated firmware that takes ours to configure…
I don’t know, maybe it’s me…
I bet people would be happy with another mode and finer spacing. I only object to the removal of the lowest mode because that would be removing a feature.
Also when backpacking/bikepacking in groups of 3 or more not many of us bring an extra light. Redundancy comes from the group size.
I got a Cometa that runs bistro/biscotti/baguette/whatever, and all this crap is selectable. Moonlight on/off, hml/lmh, mem/nomem, buncha modegroups, etc.
I think you should bring an extra AA or AAA light.
I definitely would.
Just in case the larger one fails and for low level lighting (like in a tent)
It’s not as if an AA or AAA light congests your backpack or adds significant weight.
First of all we call that single mode. We do not count “power off” as a mode, that is absurd. Absurd as some chinese cheap flashlight ads where they count “zoom in” and “zoom out” as modes.
Once you get used to having a handful of output intensity levels, it's all good.
One mode would be unpractical if the flashlight has lot of power. Quick overheating, unpractical in short distances, generally unpractical. I think Convoy makes good UI, simple 4 modes is enough for me. Sure, it could have ability to turn mode memory on or off, or have 2 groups of modes, one 20% 100% and the other one more EDC.
