too cheap to let it pass...
Hello my dear friends!
Today i present a deal where you have to be QUICK, because its very limited!
(follow my links to the shop page for detailes info)
My code lowers the price from $139.99 to US$ 84.99!
but it works only 30 times – when its gone its gone!
please contact me if you are interested!
Specification:
Brand & Model: | Astrolux FT03S |
Body Color: | Blue / Green / Black |
Tactical Ring | Stainless Steel |
Emitter Type: | SBT90.2 |
Light temperature: | 5700K Neutral white |
Peak Beam Intensity: | 510,000 CD |
Max Output: | 4500 Lumens (max 6300lm) |
Range: | 1428 Meters Long-range |
firmware: | Anduril UI |
Battery: | 1x 26650 or 1x 21700 or 1x 18650 (not included) |
Driver: | Texas Avenger FET Driver with charging |
Reflector: | High quality smooth reflector |
Lens: | Glass with anti-reflective coating |
Body: | Silicone rubber |
Button: | Aerospace grade aluminium alloy |
Impact Resistant | 1.5 Meters |
Waterproof: | Equivalent to IPX7, do not immerse in liquids |
Weight: | Approximately 301g without cells |
Size: | 170mm* 69.5mm* 34.5 mm (length* head diameter* body diameter) |
Oh, so they are making a SBT90.2 version. I was scratching my head as to why this was so expensive. Lol
Hi Martin, code “BGX11” for Nextorch is expired
Please one Astrolux FT03S for me. Thank you so much my friend.
FT03S NEWS!
Batch one (shipping December 2019) is sold out!
Hi Martin, link goes to $18.99 so two dollars more than what you posted. I have been on the fence for this set for a year now, and it has been this price a few times before (was it ever 45 dollar?) but I need that two extra dollar off to make me buy it :innocent:
i got a nice deal from banggood.com to make the new added Shockli cells even more affordable!
12% OFF on all SHOCKLI cells with my code: MSLB
2PCS Shockli IMR 26650 3.7V 5250mah 20A Discharge Rechargeable Li-ion Battery-Flat top
Shockli 21700 Battery 4550mAh Flat top High Drain 22A 3.7V Li-ion Rechargeable Battery – 2PCS
Shockli 14500 1000mAh Button Top Unprotected 5A 3.7V Li-ion Rechargeable Battery – 2PCS+battery case
Shockli 18650 3100mAh Flat Top High Drain 30A 3.7V Li-ion Rechargeable Battery – 2PCS+Battery Case
ShockLi 21700 4000mAh Flat Top High Drain 20A 3.7V Li-ion Rechargeable Battery – 2PCS+Battery Case
@djozz
i try....
Do you know which cells are inside this shocklis?
I am searching for VTC6 and 40T.
The $2 is because of the free shipping, so…
The Shockli links don’t work.
It was not a trick.
Received today, everything is correct.
Sorry for the mistrust but lately I’ve seen many gifts that turned out to be tricks…
Thanks!
Edit: Potential short circuit in the tailcap between the spring and the track, reported by DBSAR on the FW3A , continues on the FW21.
Today I received an FW21 and when doing the visual inspection prior to commissioning it can detect it.
I will correct it by rotating the spring.
So Amutorch is another company to offer dedomed SST-40 after Maxtoch and Kaidomain (ADDED: and Nightwatch).
Can’t wait for CRI95 SST-40 to come out. Dedomed, it will be an awesome emitter.
How does the tint look on the Maxtoch and Kaidomain dedomed sst40? The one in the Nightwatch NI40 is extremely green.
