Neuh, it will be fine. It seems to use this switch:
I tested it a few years ago and it was completely fine at 16A, and probably well over that. If the electrical connections are good I see no reason to worry.
I have found the Omten switches to hold up fine til you get over 31A, then the plastic case melts and fuses the switch. (Or I’ve seen it happen, don’t know if it always will)
I agree that these currents are not suitable for small mechanical switches like these. But I’m still amazed what they still seem to handle. In the longterm you may not get away with these though…
For several of my lights that I know will easily sustain well over 30A I use Tofty switches from yesteryear. I have several of those in big lights I’ve made and they’re holding up good to high current, can be taken apart and cleaned if need be. Shame those are no longer available.
It is expensive so not many people are buying it and so it is not discussed as much as, say, the FT03 with this led (that is: once it starts being shipped)
The emitter (SBT-90.2) is pricey , yes, but not so much as the price hikes indicate. At a per-each cost of $36 it’s only a maximum of $30 more than say an XPL HI, with costs of other emitters also being fairly pricey the upgrade isn’t really all that much, or shouldn’t be.
Maybe a lot of potential buyers are put off because, 1,it’s lumintop who’s QC can be a bit sloppy & ,2, the seller is not known to look after customers very well in customer service if there are problems,as pointed out by post #37.
Not in my opinion. Neal does his best to correct any issues that people have. His one pitfall is communication. He’s a single person running his shop so he has to do everything himself. Bigger stores might have a small staff where one person can handle emails all day long. He does not. I think g_sintornillos problem with Neal was also communication related. Being in Argentina he has to know the tracking info precisely to fill out paperwork. Neal’s not good at that. The vast majority of customers don’t have to worry about that. They just order and their items arrive.
Another option is to order directly from Lumintop. I dont think they had a store until recently. I dont know how good or bad their stores communication is, but maybe it’s faster than Neals?
I guess I can mention Lumintop, also. I don’t think their QC is any worse than any other company. Even “high end” companies like Acebeam, Olight and Thrunite have their QC issues. I think all these companies try to find that right ratio of precision to speed when making these products. It needs to be made precise, but also quickly because they have lots of customers waiting and a slow assembly line costs them money. So there is always a certain compromise.
If you do get into flashlights, it’s always smart to learn to take them apart and fix them just in case you get one with a problem.
