It was not a trick.
Received today, everything is correct.
Sorry for the mistrust but lately I’ve seen many gifts that turned out to be tricks…
Thanks!
Edit: Potential short circuit in the tailcap between the spring and the track, reported by DBSAR on the FW3A , continues on the FW21.
Today I received an FW21 and when doing the visual inspection prior to commissioning it can detect it.
I will correct it by rotating the spring.
So Amutorch is another company to offer dedomed SST-40 after Maxtoch and Kaidomain (ADDED: and Nightwatch).
Can’t wait for CRI95 SST-40 to come out. Dedomed, it will be an awesome emitter.
I have sst-40 De-Domed 5000K in Astrolux EC01. it’s surprisingly throwy considering OP ref and size. Green on lower currents but at full throttle becames acceptably neutral.
Max - (M4X?)
I had a couple of full-priced Astrolux items in my cart & tried to use “AXMAS”. I got the error message “This coupon can only be used on products from a specific brand and on orders over a certain amount.”
Could you confirm the code and conditions?
Thanks for all you do!
