It was not a trick.
Received today, everything is correct.
Sorry for the mistrust but lately I’ve seen many gifts that turned out to be tricks…
Thanks!
Edit: Potential short circuit in the tailcap between the spring and the track, reported by DBSAR on the FW3A , continues on the FW21.
Today I received an FW21 and when doing the visual inspection prior to commissioning it can detect it.
I will correct it by rotating the spring.
So Amutorch is another company to offer dedomed SST-40 after Maxtoch and Kaidomain (ADDED: and Nightwatch).
Can’t wait for CRI95 SST-40 to come out. Dedomed, it will be an awesome emitter.
I have sst-40 De-Domed 5000K in Astrolux EC01. it’s surprisingly throwy considering OP ref and size. Green on lower currents but at full throttle becames acceptably neutral.
Max - (M4X?)
I had a couple of full-priced Astrolux items in my cart & tried to use “AXMAS”. I got the error message “This coupon can only be used on products from a specific brand and on orders over a certain amount.”
Could you confirm the code and conditions?
Thanks for all you do!
Features:
1. Astrolux A01UV is an extremely compact ultraviolet flashlight, emits an average wavelength of 395 nanometer.
2. Powered by a single AAA battery, easy to get
3. Practical Design: Made of durable aircraft-grade aluminium with anti-scratch Type-III hard anodizing.
4. Light and Tiny: Ultra-compact design provides easy connection to a keychain for every day carry.
5. Fully tighten the head to turn flashlight on. Slightly loosen the head to turn flashlight off.
6. Multi-function as UV rays flashlight, Fluorescence detection pen, Sterilization detection pen, phony detection pen, etc.
That Xmund FL7 looks pretty interesting. The body reminds me of Rofis MR70. This does not use a boost driver though, just a 3v driver with SST-40. I cant find any info on it, but previous Xmund have terrible UI’s. Their pictures are very deceptive as well, not accurate at all.
My question, does anyone make a similar light with same features (built in charging, side switch, 3v led 26650 body), but higher quality?
