I wanted to make high walls (around optics) and put nice gitd o-ring in gap between optics and bezel, but I’m not now I’m not sure in this decision. I guess many triple boards are not round or oversized (while optics is very precise).
Are the P60 shells the same as the ones I purchased from you or have they been changed? I don’t see pics in the OP?
Uhh, good question.
You have purchased many of them.
Previous batch (when Cu ones were also oversized, and driver cavity was not as deep as before) design got minor changes. Many years ago I added an extra step at the top, it was needed to align centering ring for triple config. Since centering rings are sold out, nobody asked me about this option, so this time I decided to exclude this feature. Now there is just 1mm flat rim around PCB place.
P.S. Anyone else have problems with photos in OP?
Thanks!
Pulling the walls to the top, under the glass is a bad idea and you answered why. They are of different sizes. L4P are slightly thinner than e.g. Noctigons.
1mm flat rim is enough, just to center the mcpcb.
And instead of a glowing O-ring you can paste gitd tape from the inside and it looks good too.
I bought a quad spacer for Convoy S11 from you which have high walls. I wanted to put 4x Luxeon V there and I don’t know if I can just put the mcpcb on the thermal paste or I need to solder it.
If I put it on paste, I don’t know if the mcpcb will be properly pressed to dissipate heat. This is because the L4P quad is 1.6mm high and the Noctogin is 2mm.
If I have to solder it, I don’t know how to center the mcpcb, because it is 20mm, while the place is for 21mm Noctigon.
I can see photos.
As far as I remember, you have S11 set (Cu spacer+brass ring). If you need to use thinner PCB, you can sand down the bottom of the brass ring. Also, you can fix brass ring on spacer in right place with a solder or thread locker. Anyway, if you are not sure in right combination, putting them together without solder/thermal paste/wiring is always a good idea.
You can use the central hole in spacer for PCB alignment. CNC made batches have 4.2mm hole, custom and rare parts have 4.0-4.1mm central hole. If you need, I can add a 4.2mm drill to your next order. Use work side (for undersized holes) or shank side (for 4.2mm holes).
1.5mm o-ring can be compressed by 0.3mm with ease, while thickest 20mm triple boards are 1.75mm thick.
I just don’t see another way to get optics centered. Parts are not aerospace precise and need some room for easy fit. I need to give some extra room, if the next batch of hosts will be made by another vendor, my spacers still should work.
Pill top is flat, a spacer is roughly centered inside head walls. PCBs are not perfect in size and roundness, also some of them don’t have chamfer at the bottom (this means I need to add at least 2x minimum tool radiuses to the ID size). All this gives a reasonable amount of side gap, and the build will always end up the same way - you will get optics off the bezel hole. This is not a problem for S2+ (when 1.5mm of optics hides inside bezel), but S21A bezel opening is 0.2mm over optics size - so you will see any misalignment and it will look awful.
A solid copper pill for triple would be better than spacer that will be hard to solder well on the flat surface
I got the spacers the other day safe and sound. Thanks and Happy New Year.
Just wanted to say thanks to kiriba-ru that manufactured the copper pill and brass ring for my Amutorch VG10 that I will use in the OL contest!
Perfect pieces Thanks for your work!!!
Mr. Ru…
I’m looking for parts for S2+ and a C8. Throw throw throw throw. Don’t give a hoot’n’shit about CRI and I prefer blue-er light. Got anything in stock to fill the bill?
(I am aware of that thing called the ENTIRE EARTH in-between our locations, which I am fine with waiting on long shipping)
PM sent
kiriba-ru, can you tell how much do these S11 spacers cost?
I don’t even have an host, but that light seems quite nice, so I’m just thinking of what to do !!
Thanks in advance
Thank you
As soon as I decide for the host, I will let you know and ask the piece :+1:
Ruble have fallen down (as usual) so I was able to reduce prices by 15-20%.
I still have several quad mod sets for Manker U11, no ideas about how they fit the new hosts. Available for free.
will the quads fit in a s2 convoy?
No, even S21A is not big enough for quad.
