Not even close. My FT03 SST40 is a flood light compared to the crazy tight beam of the K1 W1. This picture shows both lights about 25 feet from the wall. Both lights are set near the low end of their intensity range. And, yes, the SST40 really is that ugly green tint :confounded:
W2 = wider but less intense hotspot, more heat, less runtime
If the goal is to make a small area as bright as possible, W1 should work better. The extra lumens of the W2 model don’t make it brighter, they just make the hotspot bigger. Basically, it’s a choice between a spot 10 units wide and 13 units bright, or a spot 15 units wide and 11 units bright.
The W1 uses 4.9A on turbo. So with a 5000 mAh cell, runtime in an ideal scenario would be about 61 minutes.
The W2 uses 7.8A on turbo. So with a 5000 mAh cell, runtime in an ideal scenario would be about 38 minutes.
In both cases, any voltage excess between the input and the output is discarded as heat.
All other things being equal, higher-amp cells tend to maintain higher voltage under load, so they have more excess voltage to discard and tend to make a bit more heat. They also are able to stay in regulation for more of their total runtime, and then drop off faster once they fall out of regulation.
The goal for a linear driver like this is to keep the input voltage just slightly above the output voltage. This keeps the output flat while maximizing efficiency and minimizing heat.
Since the K1 W1 uses a maximum of 4.9A, the amps aren’t really high enough to need a high-amp cell. Extra voltage from a high-amp cell would mostly just make the regulation circuit hotter. High-amp cells almost always hold less total energy too, which reduces runtime. More heat, less runtime.
So the best batteries available are probably the high-capacity type like 50E, which aims for maximum mAh.
This light looks awesome! I only have one Osram light and dang it is a tight spot. Just waiting for some more beam shots to decide on best emitter. If you just want throw go with the w1. Gonna be tight!
Thanks for the great replies. Thank you, @Toykeeper for clarifying all that for me. I continue to lean toward the W1 and appreciate the battery advice. Anyone know the beam angle of the hotspot only (Please tell me if you’re using half beam or full beam) for the W1 and W2?
Or tell me how wide the hot spot is at any specified distance from 10’ - 20’?
I love the style of the design because of the slimmer battery tube and large head. I would not have bought it had there been a 26650 sized battery tube.
Mine has been sitting at JFK since the 16th. Frustrated because I ordered my D4V2 at the same time, they shipped together and traveled side by side with 4px. Then my D4 continued and arrived, while my K1 hasn’t moved……
