ReyLight LAN special edtion.
From left to right, #1-5.
With new deisgned tail and programmable driver.
700$, free DHL shipping. You can choose Nichia high CRI, max 470 lumens, or XPL, max 800 lumesn.
Very limited supply, I just soldered 5 of the new drivers. 1st release is only 5pcs. Total will be no more than 15pcs.
Reverse clicky switch. Full click to turn on or off, half click (tap) to cycle modes.
Battery reverse protection.
High temperature protection.
Low voltage protection.
Program: When the light is on, quickly half click 8+ times.
1. Select different modes groups. (1-4 groups)
2. Turn on of off memory function. (Default is off)
3. Turn off or on moonlight mode. (Default is on)
4. Mode order. L-M-H → H-M-L (ascending or descending)
5. Reset.
Shortcuts: Quick double clicks = turbo
Modes groups #1-4.
1. moon-2-20-100%
2. moon-10-40-100%
3. moon-2-10-50%
4. moon-50-100%-strobe-SOS
Video here: Timascus LAN | Rey Ye | Flickr
The 4th one was taken.
Rey they all look fantastic!
Will that style of tail be used on the next version of the regular Ti LAN?
I’ve been looking at your site and toying with getting a Ti LAN but would prefer this new style of tail for sure.
Is this an anodized dip?
Is switch new too? I love my 16 trit ti lan but switch rattles, they all do.
How is clip? Does it sit flat or still push on tailcap? They were not perfect fit and this is same clip from what is seen. They’re are under much pressure and push hard on the end caps.
Will the clip also scratch finish? It is very tight due to the tight fit.
Why include charger and battery. Is this battery proprietary or, with the new end cap, can not all 14500 brands protected or not fit ? Is there some restrictions which battery fits?
Are trits included at this price?
Thanks,
Yes, I might use this new tailcap for the future regular lights production.
It is forged titaniums with heat treatment.
To make this type of tailcap, I had to make the diameter a little bigger. The clip sits well on the body. If you worried about the scratch, there is a ti washer to replace it.
Just wanted to include charger and battery to make it a complete kit. Nothing special about that. Both protected or unprotected are fine.
Some battery with USB charging port might be too long though.
Tritiums are not included.
