LT1 arrived today 12/24 after ordering on 11/29 as a black Friday special. Less than a month is pretty fast. I couldn’t believe that I got it for $53.xx after using multiple coupons and codes, until I saw it arrive. That’s with batteries!
Thank you to the LT1 development team, at both BLF and Sofirn.
Mine is in shipping limbo too. Ordered November 21st, “shipped” November 29th, and that’s the only information that Amazon has. Both “aftership” and “17track” show nothing for my tracking number. :-/ Since it has theoretically been shipped for almost a month, I’m hoping it just pops up at my mailbox.
I am so pleased with it, it’s easily the best light-related piece of equipment I ever got hold on since I’m into flashlights. Thank you DBSAR, ToyKeeper, SIGShooter, Sofirn and all others who have made this possible.
I recommend this case for JBL Flip 4 Bluetooth speakers: https://bit.ly/2EPWHWS
Not only does it fit like a glove, it also provides storage space for the manual, spare O-rings and the charge cable:
If you look closely, I added some O-rings outside. The top got a 60x5mm ring, which sits really firmly and should provide good cushion in case it topples over. I also put 40x2.5mm rings over the base to provide a better grip.
And, in case someone is interested, here’s how I modified the USB coding:
I found my charge end voltage to be 4.17V, which is perfect. A bit lower than 4.20V is always good, as it stresses the cells less. I also found the voltage indicator to be extremely precise. I supplied voltage with an adjustable lab power supply, and just as the voltage changed from 4.04 to 4.06V, the lantern changed from indicating 4.0V to 4.1V. Same when going from 4.14V to 4.16V.
I got my code to buy my other light(s?), but with cells only. I had to reply to request a code for no cells. I haven’t heard back yet but I’m in no hurry.
The inner diameter is 40 on mine, the 45 one from ebay is measured at the outside, so its 39 inside which is ok. 2.5 width is what I had at hand, but the grooves are slightly wider than that, so 3 or even 3.5 would also work just fine.
