Tonight or tomorrow I will set it up on the bench and take some more readings.
I brought a second one and plan on scratch building a host with better cooling for the other. Now i have a k75 host thinking an osram LED with L4P driver.
yeah… throw… woooo it’s de-domed… :money_mouth_face: Heat not so much these Big Luminus LED’s are current hungry, they pull big amps…and are tough as iron nails…
I took the window off the led
The k75 as a host is light weight with a huge reflector so i will put the 2mm2 osram and led4power driver in it, see how it goes. The astrolux battery tube fits and I have changed the battery carrier to 4s which fit the acebeam tube. However the acebeam carriers dont fit in the astrolux tube
I am waiting for more leds so i will do a test with Q8 driver and the sbt-90 from the k75. I have a host knocked up for test.
The k75 driver and led will go in a aspheric with a collar and 150mm lens with 177mmFL. i have done some tests without the collar and and 145mm lens, looks like it will be alright
Yes this is what I find as well. My low voltage indicator starts blinking when on Turbo mode and my batteries are at 3.5 volts. The light then shuts off completely as the voltage sags below this. I stick the batteries in my VC4 charger and the dial is 3.5v
Sorry for the delay replying I have worked every day over the christmas break and havent had any time to do anything.
It is a stainless steel butt weld dome endcap that has been polished, the opening is not the right size because it is one that was already cut for another use. the idea is the light that doesnt hit the lens is reflected back to the light emitting surface and increases the intensity. I have a thought that more than one led can be used but the extra leds are blocked by the aperture so that only the centre is exposed to the lens. the inverted reflector may have to be a different shape to properly focus the extras.
I think you are right the stainless endcap doesnt focus a clear image, but it is worth a try. Sometimes you have to spend a bit on materials and tools to get results.
