Seems relatively new to the market.
I’ve been looking hard for for a good cordless electric screwdriver… Hope this is a good one, cause I just bought it. Pretty compact for what it is and the all metal gearbox sold me along with the Wiha name brand.
Pretty much all my cordless tools are Milwaukee. But wasnt looking to spend $100 on a screwdriver plus another battery (4V) form factor.
All 15 reviews on BG are positive. And other reviews are scarce.
Got $5.55 off the total, Now $31.44 with coupon :
BG11BB
BGPowerTool15
Sorry but I think the links and codes are for USA only. I dont know how to get international links or codes. And again this a NON Affiliate link. Just posted my findings on the screwdriver I bought.
Looks like an improved version of the Wiha SpeedE ($240) that used 18500 batts but those were removable KeepPower cells. And the speedE also has drawbacks with its design, how it it is turned on to screw with sensing torque and its low 0.4Nm motor stall torque… I would much rather have buttons.
I couldn’t find a linkable pic of the gearbox pic but it appears to have cam rollers to help hold it tight while hand tightening or loosening screws. Keeps the torque off the gearbox itself. This one has 2 motor torque settings. The 0.4Nm and 1Nm which is only 3/4 of a Ft/Lb or 8.85In/Lbs.
And it supposedly has an 18650 inside. Hate to admit it but this will be my first device with USB C. Who knows… top cap kinda looks like it may come off, but doubt it.
Had a couple B&D electric screwdrivers and both were JUNK. Plastic gears and plastic hex holder inside that will round out with one twist.
Been looking lately and only 2 have caught my interest after researching.
Looking for something small … I narrowed it down to the Bosch or Dremel (same company) or the Skil or HammerHead, again same tool different branding. But I have no clue of whats inside them as far as the gearbox.
Only found this one today and bought it. Should be here in 7-20 days
$34 to my door, I took a chance. I have a German tool fetish. Wiha is German… Xiaomi Mi makes good stuff too. So we will see if I made a good decision.
I like the Bosch Go mini screwdriver a lot but I also find it doesn’t feel “right” to me when unscrewing a screw. Something about having to push the screwdriver into the screw to turn it on when unthreading just feels odd to me. It is great for tightening. I am a bit odd in some ways myself though.
I had a dremel cordless screwdriver that lasted for years, I believe it had 2x 18500 in series and was rated 7.2V. It was even fully submerged in water and still worked… I don’t know if the new one is built the same.
For some reason I don’t feel xiaomi tools are made to last. I had the $20 precision bits set and started showing rust spots after a few months.
I clicked on this thread with extreme interest. I would buy a few of these for X-mas gifts and one for myself as well, if found to be built with any quality at all.
Power screwdrivers are a great concept for many home “some assembly required” purchases. Speeds up the assembly, with less risk of using a high powered drill. Saves on the aggravation, and sore wrists.
I have soured on Black and Decker products after finding my drill/driver set showing rust spots when I went to use them, stored unused in my fairly dry basement.
Are there any decent power screwdrivers out there?
I too have this Bosch Go mini. I agree with MtnDon. While it’s so ‘torquey’, having to push the whole thing to make turn-on, even unscrewing, makes its UI the weirdest design I ever encountered. Had I known before….
…and now this Wiha Zu Hause has got my attention.
Does anyone know if pressing no button will lock the driver?
Just got an email that my Wiha screwdriver wass released from US Customs in NY. I should have it in a few days.
Also got a PM from a member that the code in the OP is no longer valid. I found a couple more codes that I hope will help. I will also post them in the OP.
BG11BB
BGPowerTool15
I bought the Mini 121 for my hard to buy nephew for Christmas after seeing a Marco Reps video where he’s using it on a project. All the engineers where Nephew works love it (he says), but it’s way too damned expensive for me to own, I’ll stick with a cheap manual one:-)
Thanks. Looking forward to your impressions. I don’t have a real driving need for a power screwdriver, but have always had the thought of getting one eventually. Xiaomi makes some good things. I have one of their very unusual design LED table lamps, with a dual LED setup. I could never get the WiFi app to work for remote control, but it wasn’t a big deal. It’s a really neat concept that Xiaomi pioneered with Philips (LINK).
That Mini 121 and even the 120 are NEAT. But… not something I would buy for that coin.
I do have the AAA USB rechargeable WOWStick. Only use it occasionally, but I do like it for small screws.
First impressions: This thing is Flippin Neat.
Came fully charged (I think) cause the green light came on as I plugged the USB-C connector into it. As it charges there is a Green LED that appears to be breathing as it ramps up and down.
Need to hold in the torque button in to get it to change setting. Green is the low and the 2 smaller bits are color coded to help recall settings. I can stop the driver with my hand in low and it will flash a red LED once it stalls. Orange is the high torque setting. I can Not stop the bits with my hand on High or Orange setting.
This has a Great Solid Feel to it and has some weight, certainly does not feel cheap. Really feels like a quality tool in hand. Handle is rubberized from about the reverse button to the tail cap. Nice texture and feels durable. I didn’t realize at first it was a different coating till I torqued on it and can also feel its softer with my fingernail. For me there is enough room on the rubber section of the handle to really get a good grip without touching the buttons.
2 LED lights at the front are positioned where they light up the area needed pretty well. But only light up with the direction buttons pushed. Would be nice it they had a 3 second delay to turn off the LEDs. That would be enough time to locate the screw head and get the bit ready to remove the screw without having the bit turning to light up.
Bits are all Wiha branded and seem of good quality. Bits are nicely uniformly cut. No branding on the extension. There does seem to be a magnet in the handle to hold the bits in but I cant get it to pickup or hold a screw. The extension has a ball-detent to hold it firmly in the handle and holds in good. Magnet in the extension is Strong to hold bits and screws.
On the handle it is branded:
Screw Driver 4129
Wiha Tools (Shanghai)
Made in China.
I think it shuts down after setting a few minutes. Hard to tell this early on… but twice now I needed to press the direction button 2X to get it to turn. Correction: does seem to shut down but it only has a fraction of a second delay if you hold a direction button after it’s been sitting for a while. Otherwise pushing a direction button is instant motion.
Sadly… The back cap don’t come off. Perhaps it will after some use and a few drops on the floor. But I can’t force my luck on my new toy.
Well, that’s my first impressions of it so far. Happy with it but it hasn’t really been tested yet.
Welcome,
Will do another update when I get a project to really test it out.
But so far I am impressed with it. Certainly has a place in the toolbox next to my Snap-On and Hazet ratcheting screwdrivers.
Added some slight updates to the post #17… like the Country of manufacture, charge indicator and some info bout the delay after sitting.
