Yeah, it may be someone forgot to update the description. That’s the old SF13 number.
I am very curious what the differences are between first and second SF13.
Is it a different LED? Different driver?
I ask because I modify 2AA lights for older neighbors —- always replacing the LED with a high color rendering LED or an amber LED for pedestrian safety.
So I can get the older SF13 online several dollars cheaper — if the only difference is the LED.
I received my Q8 diffuser, installed a cone of aluminum foil inside the diffuser. Now I have a decent replica of the LT1. Only CW tint, no bail handle or battery charging, but in a pinch I’ll have a second lantern type light at my disposal. Yes, I have used the Q8 in ceiling bounce, the reflector/diffuser setup is much more effective at spreading light around a room.
i saw the addition of various LED choices for the C8F, that is great news. May I suggest that beside domed LEDs you would also add triple XPL-HI in neutral white 5000K or triple SST20 4000K 95CRI? Or at least the possibility to order the triple MCPCB with these LEDs (XPL HI or SST20) already reflowed? Thanks!
