Yeah, I did, but compare with the search functionality to limited the condition/filter the guest want to see, the search functionality of web browser will not be the good one
Dear HKJ,
Do you mind to have a look on this device ?
https://enerprof.de/en/chargers/power-adapters-5v/433/enerpower-ep-10b-5v-2a-usb-black-10w?c=30
I tried to find Enpower USB 1 port 2A as your test but seem it was too old device so that could not find in the market, just can order enerpower-ep-10b-5v-2a-usb-black-10w now. Thank you
Barkuti
(Barkuti)
December 1, 2019, 6:05am
634
I've been looking for a DIY power bank case with some extra functionality and found an interesting device for the DIY crowd a while ago, an inexpensive power bank/mobile power supply box from (?) AILI, takes six cells in 3S2P arrangement:
Not yet interested in such a thing, at least not now, but thought I should share.
Seems a decent device but for it to work properly needless to say use good cells and preferably solder/spot weld the connections. Video:
And please, don't do like the following guy from this ad :
Hi HKJ,
could you have a look on this model (cheap but seem quite powerfull as I tested, output with current 1.03A) but not sure about its noise
ACA1AUSCWH3
I got from Lazada
https://www.lazada.vn/products/sac-energizer-cl-1a-1-cong-mau-trang_aca1auscwh3-i104051152-s105028062.html?spm=a2o4n.searchlist.list.2.649a5c29W2IOZA&search=1
I tried to contact with local DHL service to send it to EU area (you mentioned you are in Denmark) BUT the delivery cost is more than 12 times of the charger price, sorry, your living area is quite expensive so send smth like this charger
Thanks
HKJ
(HKJ)
December 18, 2019, 8:03am
636
DHL is usually rather expensive to use, normal postal service is much cheaper. It might, of course, take a few month for it to arrive then.
HKJ : I just got this https://www.aliexpress.com/item/32814087598.html?spm=2114.12010612.8148356.8.5b615b95HbQGBo , all things are good but still have no idea about its noise. Could you set this in your test list in future ? thanks
angerdan
(angerdan)
January 12, 2020, 8:19pm
638
Barkuti
(Barkuti)
January 24, 2020, 1:16am
639
Hello!
Just dropped by to say that I've found something interesting. It's an USB powered soldering iron, looks close to the one which once reviewer Dave from EEVblog tested:
But it evolved…
… into this new super cheap Aneng LT002 soldering iron!
https://www.aliexpress.com/item/4000650074912.html ≈€3.67/$4.01 shipping included there right now, crazy!
I bought the first version long ago, it's slick. :-)
angerdan
(angerdan)
March 21, 2020, 7:07pm
640
HKJ
(HKJ)
March 21, 2020, 7:45pm
641
That looks very interesting, except when you see the price.
I would need some serious donations before getting that, but I would also need to make some test equipment that can test power at 230VAC (I am sort of thinking about doing that).
The problem with testing 120/230VAC devices is to have a load that can handle AC at 350VACpeak with constant resistance (Constant current is basically useless, a high peak current test may be interesting).
angerdan
(angerdan)
April 11, 2020, 6:17pm
642
NITECORE FSP100 100W Foldable Solar Panel is Released
NITECORE, FSP100, solar panel, foldable, 100W, 24%, DC, USB-C, dual USB-A, light weight, portable, road trip, outdoor activity
https://charger.nitecore.com/product/fsp100
HKJ
(HKJ)
April 11, 2020, 6:46pm
643
I do not test solar panels. I do not have that much sunshine and I cannot easily simulate it.
angerdan
(angerdan)
April 19, 2020, 7:22pm
644
Hi HKJ, what do you think about the already posted powerbank?
Here are some 15 new suggestions for USB chargers and one powerbank:
Alster UPS Power Bank 9V / 12V / 16V / 19V (BUB50)
alsterplus.de/index.php?route=product/product&path=24&product_id=53
AUKEY Quick Charge 3.0 USB Ladegeraet 3 Ports USB Netzteil mit AiPower Tech
ebay.de/itm/AUKEY-Quick-Charge-3-0-USB-Ladegeraet-3-Ports-USB-Netzteil-mit-AiPower-Tech-fur/392608628698
Aukey Quick Charge 3.0 Multi-Port USB Ladegerät 6 Ports 60W USB (PA-T11-YYDE, EAN 0701979449226)
ebay.de/itm/AUKEY-Quick-Charge-3-0-Multi-Port-USB-Ladegerat-6-Ports-60W-USB-Netzteil-fur-S/352702883483
amazon.de/AUKEY-Multi-Port-Ladeger%C3%A4t-Netzteil-Samsung-Schwarz/dp/B01EH11AS8
Baseus 60W Speed Ladegerät Quick Charge Netzteil Schnellladung 2x USB-C 1x USB (B-1241)
ebay.de/itm/Baseus-60W-Speed-Ladegerat-Quick-Charge-Netzteil-Schnellladung-2x-USB-C-1x-USB/283624594209
Baseus USB C Ladegerät 65W mit GaN Tech 2 PD 3.0 Ports + QC 3.0 USB Schwarz (EAN 749038375864)
ebay.de/itm/Baseus-3-Port-GaN-65W-Schnell-Ladegerat-AFC-QC4-0-PD-SCP-Netzteil-USB-C-Stecker/133344044135
CSL-Computer Multicharger Wallcharger USB Typ-A 2x, Typ-C 2x, 90 Watt, Quick Charge, 4 Port (PD-010PT, EAN 4250874897893)
ebay.de/itm/Multicharger-Wallcharger-USB-Typ-A-2x-Typ-C-2x-90-Watt-Quick-Charge-4-Port/372940854783
DIGITUS Universal Travel USB Ladestation 40W 2x USB A Quick Charge 3.0 USB C (DA-10194, EAN 4016032430070)
ebay.de/itm/DIGITUS-Universal-Travel-USB-Ladestation-40W-2x-USB-A-Quick-Charge-3-0-USB-C/193422939850
Delock USB Charger 1 x USB Type-C PD 85 W + 3 x USB Type-A Qualcomm Quick Charge 3.0 (41432, EAN 4043619414321)
https://www.delock.de/produkt/41432/merkmale.html?setLanguage=en
Hama Charging Station, 5-way (1x QC 3.0, 1x USB Type-C, 3x USB), 8A, black (00173627, EAN 4047443357281)
https://de.hama.com/00173627/hama-charging-station-5-way-1x-qc-30-1x-usb-type-c-3x-usb-8a-black
ebay.de/itm/Hama-Ladestation-5-fach-1x-QC-3-0-1x-USB-Type-C-3x-USB-Quick-Charge-NEU/223706919486
Hama 65 Watt Charging Station, 4-Way (2x PD USB-C, 2x USB-A), black
de.hama.com/00183376/hama-65-watt-charging-station-4-way-2x-pd-usb-c-2x-usb-a-black?bySearch=Charger%20%26%20Power%20Supply%20Units
https://www.google.com/shopping/product/13506289797591665392/online?prds=scoring:tp&sa=X
InLine Quick Charge 3.0 USB power adapter, charger, 4x USB A + USB Type-C, 40W, black (31509S, EAN 4043718267064)
inline-info.com/en/products/power-energy-light/usb-power-adapter/10573/inline-quick-charge-3.0-usb-power-adapter-charger-4x-usb-a-usb-type-c-40w-black
InLine USB Netzteil, 4-port Ladegerät, USB-C PD+QC4 / QC3, 45W, schwarz (31512S, EAN 4043718285556)
inline-info.com/en/products/power-energy-light/usb-power-adapter/11159/inline-usb-power-supply-4-port-charger-usb-c-pd-qc4/qc3-45w-black
ebay.de/itm/InLine-USB-Netzteil-4-port-Ladegerat-USB-C-PD-QC4-QC3-45W-schwarz/174253044703
InLine Quick Charge 3.0 USB notebook power supply, 4x USB A + USB Type-C, 80W, black (31510S, EAN 4043718279579)
inline-info.com/en/products/power-energy-light/usb-power-adapter/10930/inline-quick-charge-3.0-usb-notebook-power-supply-4x-usb-a-usb-type-c-80w-white
ebay.de/itm/InLine-Quick-Charge-3-0-USB-Netzteil-Ladegerat-4x-USB-A-USB-Type-C-31510S/274259846236
i-tec Universal Charger USB-C Power Delivery + 4x USB-A QC 3.0, 80 W (CHARGER80W, EAN 8595611702723)
CHARGER80W (EU), CHARGER80WUK (UK) | i-tec USB-C Universal Power Adapter 80 W – 1x USB-C port 60 W, 4x USB-A port 20 W, for laptops, tablets, smartphones, supporting HP, Apple, MacBook Pro, Dell, Acer, Asus, Lenovo and many others
Uniq Surge Charger| USB-A, USB-C, 90W, PD, QC 3.0 (EAN 8886463668108)
ebay.de/itm/Uniq-Surge-adowarka-Charger-Ladegerat-USB-A-USB-C-90W-PD-QC-3-0/143545665100
HKJ
(HKJ)
April 19, 2020, 6:26pm
645
[quote=angerdan]
The price is way to high for me to buy for just a review.
[quote=angerdan]
Thanks, I will check them out when I am low on chargers to review.
At the current time my reviews are slowed down, because I am working on a project that requires a lot of time.
angerdan
(angerdan)
April 20, 2020, 9:33pm
646
Yea, 180€ is some money. What about asking the shop for an copy to review?
All of them offers at least 2 ports with eather PD or QC.
I’d add some more very interesting chargers.
And created some table for the features:
Sounds interesting, will you publish the results?
Do you want to spoil some general details, like what general topic it is about?
I believe everyone here on BLF knows the value of your work.
It’s really helpful.
HKJ
(HKJ)
April 20, 2020, 9:34pm
647
angerdan:
The project is already on BLF: Logging from meters
And on EEVBlog: Program that can log from many multimeters. - Page 1
angerdan
(angerdan)
May 16, 2020, 9:18am
648
DIGITUS Gigabit Ethernet USB Type-C PoE Splitter, 50 W, IEEE802.3bt
angerdan
(angerdan)
May 26, 2020, 4:52pm
649
I second Barkuti’s request for the Aneng LT002 Soldering pen.
