✌ FREEME- ASTROLUX MF01 Mini 7*SST20 CRI95 26650 ANDÚRIL Flashlight Group Buy - $45.99
This light deserves a better home.
When i charge for the first time my mini with usb the green not turns on , after that i discharge and charge the battery with a Charger and Green turn on.
Agreed. What about a holster designed by Astrolux? I think they have sold enough of the MF01 mini that it is time for a dedicated bag.
This is normal. The charger only turns on below a certain voltage. Maybe 4.0 volts?
Agreed, id pick up a few right off the bat. The quality for the MF01S and ft03 ones were great.
After having the MF01S, I just had to have a Mini. Just picked one up in gunmetal. Thanks for the group buy, freeme!
Goy my MF01 mini yesterday in gunmetal grey 5000k… feels great its very bright on turbo, alot more then my ff e07 and d4s emisar. I just wish the aux leds on high were brighter :frowning: I thought first i was on low but then realized they arent that bright on high compared to my ff e07 or emisar… i know u can manually turn them up with a screwdriver but im not gonna bother with that… should have been possible adjusted with low and high mode in settings instead imo hen have to screw up the lens… but still a great light finish is good and the neutral tint looks good.
i like how the aux leds change color depending on battery voltage.
The mf01 mini has become my favorite in the bag light which used to be my D4s. Did some tint mixing on mine to get my new favorite CCT 3500K and turned out lovely. Very close to 3500K e21A.
mix of 3x4000K (stock), 3x3000K and 1x3500K (middle)
L-R: MF01 mini (3500K mixed SST20s), Jaxman E1 (e21A 3500K), Rofis R1 (e21A 5000K)
I have two of these: https://www.banggood.com/Astrolux-Flashlight-Protected-Bag-Holster-For-Astrolux-S41S41SS42S42S-Lumintop-FW3A-Flashlight-p-1089597.html?rmmds=myorder&cur_warehouse=CN
Fits perfect in fireflies E07 and MF01 mini too.Good quality.
I prefer lower AUX output to mimic tritium effect.
Have forgotten about this one. Will bring msg BG in the morning ASAP.
I have noticed that the small Sofirn holster is a nice fit for the MF01 mini. It is elastic and thus fits also 26650 flashlights.
€ 3,88 and worst quality than Astrolux Astrolux holster costs $1.94 :wink:
https://imgur.com/NiCz1Gm
[img]https://i.imgur.com/NiCz1Gm.jpg[/
[img]https://i.imgur.com/NiCz1Gm.jpg[/img][img]https://i.imgur.com/NiCz1Gm.jpg[/img]
On the new Sofirn website sofirnlight.com they are pretty cheap, 2.99$ for two bags with free shipping above 19$.
I would say the quality is pretty decent and it is slightly bigger than the Astrolux. Of course, the Astrolux is more compact.
Cheaper and better quality.But you decide what you buy with your money, of course.
Freeme - could you send me the code? Thanks!
Im looking to buy this light, is there any codes for the groupbuy or how does it work? The cooper is really beautiful but i want the flashlight to be as light as possible for hiking, is the aluminium a better choice?
Does the copper one get less hot than the aluminium? Thanks! :slight_smile:
They get to the same temp, but copper takes a bit longer. Aluminum should be much lighter.
What 26650 battery to get? Want a mix of output and long lasting.
A good choice is the PLB-55. Here are the brands they are sold as:
Shockli 5500mah
Keeppower 5500mah and 6000mah
Vapcell 5500mah red and 5900mah purple
Orbtronic 5750mah
