Yeah, it may be someone forgot to update the description. That’s the old SF13 number.
I am very curious what the differences are between first and second SF13.
Is it a different LED? Different driver?
I ask because I modify 2AA lights for older neighbors —- always replacing the LED with a high color rendering LED or an amber LED for pedestrian safety.
So I can get the older SF13 online several dollars cheaper — if the only difference is the LED.
I received my Q8 diffuser, installed a cone of aluminum foil inside the diffuser. Now I have a decent replica of the LT1. Only CW tint, no bail handle or battery charging, but in a pinch I’ll have a second lantern type light at my disposal. Yes, I have used the Q8 in ceiling bounce, the reflector/diffuser setup is much more effective at spreading light around a room.
i saw the addition of various LED choices for the C8F, that is great news. May I suggest that beside domed LEDs you would also add triple XPL-HI in neutral white 5000K or triple SST20 4000K 95CRI? Or at least the possibility to order the triple MCPCB with these LEDs (XPL HI or SST20) already reflowed? Thanks!
Earlier today I purchased three flashlights, some 18650 and 21700 batteries on Sofirnlight dot com. One of the torches I bought is a C8F LH351D 5000K 90CRI, It was an amazing deal, all those items for $90.
But now I see the post above regarding the C8F only being available in SST20 4000K. I don’t want it in SST20 4000K.
Hi, thank you for asking. Because the color is not standard color. Other color version will be available in late Februrary. Thank you for your patience.
