From what I can see, the contacts are clean, springs are clean and tight, edge of the battery tube is clean, o-ring is properly seated and I don’t hear any rattling.
I used a pencil eraser on the main contact ring, cleaned away the eraser dust, then wiped it with a rag and a tiny amount of Ballistol, then wiped clean.
I haven’t taken anything apart besides opening the battery compartment and rear tailcap but don’t see any obvious signs of scorch or anything loose.
I don’t have another 18650 light but I ran the batteries through another charge cycle to full.
It was just riding in my backpack, so I’d be surprised if it suffered any major shock or impact since I’m not rough with the pack since it has a lot of other stuff in it.
Did you try removing the o-ring and fully tightening?
Since you are new to 18650 cells, can you confirm the positive end sticks up above the plastic wrapper? Some people use flat top 30Q because it just barely sticks up and sometimes it makes contact and sometimes it doesn’t. With button top cells they add the button which raises it about 1.5mm.
It seems logical the charger is working and the battery is not completely dead, but to be sure do you have a voltmeter to verify?
Other than this, it seems the driver may have gone bad. Can you solder? You can get replacement drivers for about $10. You can unscrew the bezel and driver, remove the screw that holds the reflector into place and then check the led board (mcpcb). It’s possible a wire may have come undone.
I’m new to the forum and these type of lights. I’m getting the double blink when I screw the battery in, what does that indicate?
In ramping, I’m getting to roughly (wild guess) 200 lumens and then it turns off. It’s no brighter than a 10 dollar flashlight from home depot. The light also seemingly turns on and off randomly if I leave the batteries in.
Using BXE 18650 9800mAh button tops that are protected. I went to a batteries plus store and tried out another battery with the same result.
I’ll take a look inside when I have some uninterrupted time in the next day or so.
I’m hoping that I’m in for one of those magic “take apart, put back together and it works great” deals.
If not, I may have to re-learn to solder.
Wow…. just wow. What I’m shocked about is that a brick & mortar retailer is selling absolutely dangerous crap like that. And a store called “Batteries Plus” should know that any 18650 with claims of 9800mAh is fake, fake, fake, fake.
Never go back to that store, except perhaps to demand your money back for them scamming you.
Thanks again for all of the responses. So the 30q’s have not improved the situation. I have charged them via the USB C included with the light. I hold the green button and light ramps for roughly two second and then quickly turns off. Like last time, no brighter than an out of the box $10 light from home depot. The light also still randomly comes on and off.
Any thoughts? Any experience on trying to return for an exchange?
Returning shipping to China usually starts at $60 plus there may be additional customs fees, so that is not really an option. Warranty related stuff would be them sending you a replacement head or whatever part is bad. It’s cheaper for them for you to keep the bad item.
If I had to guess, I’d say the FET is not working. Channel one uses a 7135 chip that allows .350mA to go through (about 150 to 200 lumen) and as you ramp up it switches to channel two which has the FET that provides all the higher currents.
I don’t know what could cause it turning on and off on it’s own, though.
Are you able to make a video of how it’s acting?
Are you sure it’s a Q8? Those don’t have built in charging.
As you suspected, it’s not a Q8. It is a SP36. If I’m in the wrong spot, let me know. The directions specifically cited this thread to get support.
I’m trying to upload a video. What that video displays is me screwing in the batteries and receiving 2 blinks. I feel like your hypothesis is directionaly correct. Instead of moving on to a higher power it simply shuts off.
I sent Sofirn US an email so hopefully they have some input.
Note: It’s hard to get a video of it turning on and off. That said I just saw it light up across the basement unprompted ha.
The SP36 driver is basically the same design as the Q8, but with a charging circuit designed in. It’s still a single 7135 chip and FET design. So what I said before still applies. If the FET is not working then you only get from moonlight to about 200 lumen. Some early versions of this light used NarsilM and later versions used Anduril. Unless I’m mistaken, both user interfaces use the same basic method of transitioning between channels one (7135 chip) and two (FET). As you ramp up once the 7135 chip reaches full output it stays there and the FET starts to add power.
So a bad FET would make it ramp up the 200 lumen and then just stay there. A double click to Turbo would shut off the light as that is the only brightness level that uses the FET only.
It definitely sounds like you have a driver problem, unfortunately the SP36 driver is glued in and not easily replaceable.
I would contact the store you bought it from to see about getting a replacement head or whole light.
I imagine you folks know this but I traded emails with Sofirn and they couldn’t have been more responsive and helpful. I provided a video and we tried some basic trouble shooting. In the end, they are sending out a replacement. Thanks again for all of the help here.
So I finally managed to check the connections and everything seems to be nicely attached. I didn’t see any scorch marks or anything obviously amuck.
I decided to pick up another light to test and it won’t light either. I’m guessing that there’s a problem with the batteries or that I have two dud lights, which seems pretty unlikely.
I checked all four batteries on a meter and they all read around 357 or slightly higher.
Any better way to test the batteries without another light?
Any other ideas?
I’m thinking of picking up a new set of batteries but am trying not to spend a fortune just trying to get it working.
Hopefully I can get up to speed and learn a few things along the way.
