The 2mm can handle more current and performs best at 8~9A. the 1mm performs best between 4,5~5A
As said, the 4040 version can handle more heat because of its surface.
8-9 you recon ?? mm ok i could only get my hands on a 7a 22mm driver, i have it in a Z1 host and it gets hot real fast, and also in a L21A host though i have yet to take it out and compare it to the regular 1mm version
I think led4power reopens soon i will grab some of his beast drivers…
I have also ordered some of the Green 1mm cslnm1.f1 these are significantly more powerful than the regular cslnm1.tg white flat and even more powerful than Culnm1.tg, im not sure what the Djozz drive figures are but just the bone stock figure eats the others alive
stock drive 4000ma @ 1450lm
You can bet your A* im dropping one of these in the Crelant with a 5a driver the day it arrives
Thanks Jozz, so it looks like it will be quite happy with a 6.5-7a driver, should be pretty impressive in a jax or similar host , shame its green but hey
When they arrive i will drop one into the Crelant and head to that same lake for some photos!
For plain seeing things this green beam is best but for figuring out what you are seeing, white is much better.
Edit: for fun I did another beamshot with the GT-micro (14500battery, 29mm reflector) with this “Green Flat”. It is amazing how far a toy-size flashlight gets with this led (tree trunks at 25 meter, pingpongtable at 80 meter, houses behind at 120 meter, exposure just about adjusted to what I see with my eyes)
Hmm, don’t know what to think of this LED, usually people only complain about greenish tints
This is somewhat greenish indeed but let’s not exaggerate the issue…It throws nice!
gave one a go today, really packs a punch but It’s kinda nasty has a really eerie pale green glow like some alien search light
very unnatural color
TFC,
You could make small business selling those greenies to UK hunters. They won’t mind…
Hunters Green…. Sadly i think Nightmaster beat us to it a few years back with their green envy series
They were charging obscene money too!
I just ordered the 20W green flat for building a pill for my B158 for just that!
I tried it, it has the strength but I was disappointed with the color, because its is converted gree it is quite light green tint, almost looks like yellow. Cree XPE has much nicer tint, darker green, more intensive, but lacks in strenght significantly.
I also have Osram blue flat, 1x1 die, but did not test it in the flashlight.
Stuck one in a Jax with a 5amp driver just for curiosity…. not the best image but gives you an idea… thumbs down from me green light on green background next to useless past a hundred meters. ill be sticking with white.
Are you kidding? That looks great! You gotta to use that with riflescope or binoculars and then you’ll see
The beam in your Jax is awesome, the color though …
Looks like typical Cree tint.
It appears you have the HX and HL confused. Nice mod though! Mini throwers are a favorite of mine…
I see that Boost HL appeared on the Osram site finally:
