thank you so much for your message
we can’t provide that , so sorry
Hi everyone, i´m new here from Portugal! I have this power suply for 2 days and I updated the firmware to V1.25 and since then when I turn off the power suply it keeps the power light flashing, is it normal? Aren’t you supposed to be totally turned off? Thank you
it is normal, that is breathing light, you press the power button but there is still power connected to the input, It ’s like when you turn off the TV with the remote control, the TV is just in standby state, you do n’t remove the plug.
we update our RD6006 PC software to version 1.0.0.5
new function:
1. add French and German to RD6006 (PC software)
2. you can edit the data group value
3. You can Program the output by PC software
PC software to version 1.0.0.5 : https://drive.google.com/drive/u/1/folders/17V-JWHvqMF-NuWSznEiJ4RKrnn_Pkt5v
Hello,
I just received this power supply, and it works great.
Is there any way to set the default state to off whenever you plug it in the wall socket? I have a main power switch on my workbench and whenever I power the bench on, the supply boots and it remains on, I would like it to remain off…
You could just mount and wire in a main power switch. I used a lighted switch but it’s not neccessary, since the front panel lights up when on. https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&productId=2276503
@RDtech, waiting on a 20 amp version and I’ll buy one.
I already did, but it’s on the back panel, because I built the case before I got the power supply .
when we design this, we set it defalut on to test if it can work normally, and you can use the power button below the screen to control the on/off status, for now it cannot be changed
we plan to release it(60V24A) this year, maybe by the end of 2020, not sure about the exact time
RD6006 feedback
All the super packaging is intact, the delivery is very fast, the device is in good condition.
https://www.aliexpress.com/item/4000282551930.html
RD6006 feedback:
All right. I would like to recommend.
Hello,
I recently got the RD6006 and I love it!
However, when I connect to it over USB, the desktop app says it can’t recognize this version.
The unit shipped with firmware v1.26.
What can I do to make them communicate?
When will you be making the 20 amp or larger amperage model like this ?
can you contact my email 1749808860@qq.com? please show me some pictures to describe the problem, a short video will be much better, and I will help you to solve the problem as soon as possible
it should be designed in this year, but affacted by the coronavirus, I am not sure now
Looking forward to trying the new designed 20 amp version. Count me in when when its released.
you need wait some months, but for 12A, it will be after 3 months
