Neven, would removing the mosfet and bridging the connection on the MosX MCPCB with the Luxeon MZ allow it to be used like a normal MCPCB with only two power leads connected from a standard driver?
Interested in using one in a standard triple host without use of an LD-B4 driver.
Just one driver teaser information, there will be two main types of drivers, one clicky only (lower cost and size) and other clicky and e-switch (high end) driver, hardware concept is done on paper, next step is prototypes and of course software part. First type of driver(clicky only) will be released first. All drivers will be for 1S (4.3V), HV (1S-4S) version of second type of driver will come later, after 1S development and release.
I see…
There’s no way I will like it nearly as much as my hand-tuned Andruil.
But considering that your clicky UIs were very good for clicky UIs I expect quite a lot from this one.
There’s no chance it will be excellent for me but it is likely to be at least fair. I have some but hope that it will actually be good - but not much hope.
Bureaucracy reasons, my start-up company is not registered for trade (re-selling), so I'm technically allowed to sell only my own products. "My own products" could be basically any new product that's different from input raw material. So LED + MCPCB (soldered or not) is new product, LED alone is not new product. To get trade registration in my country you need to have >50m2 (expensive) separate warehouse no matter if you are selling 0402 resistors(and your whole stock can fit in your backpack), or cars. There was one case where inspection closed e-book store (yes, digital downloadable books) because owner did not have 50m2 warehouse for e-books LOL.
I added "don't solder LEDs and NTC" to for 20mm quad CuDTP:
I see that you have all non-IR alu MCPCBs on a sale. Does this mean that you want to switch to copper where it’s a good fit or that you have newer variants in the queue?
I plan to have new 16 and 20mm DTP boards in 3030,3535 and 4040 footprint format,and possibly 3x,4x 20mm 3030,I'm not sure about the rest, demand is too low.
Sounds like you need to add a new product - a 30mm x 120 mm strip of bare copper. Label it “LED test fixture, holds up to 12 LEDS” and have a “Do Not Solder LEDS to test fixture” option
Neven,
Glad things are up and running again and I hope you have a good year. I’m very interested in either 3x or 4x (preferably the latter though) 20mm DTP MCPB in 3030 footprint. I need some other things and I’m debating about whether I should wait to order until these boards come out. Do you have a rough estimate on when they might be ready? Thanks.
