This does not work either. I use Windows 10 Pro.
Do I have to be registred at launchpad? And do I need that ssh key file?
see: Bug #1807226 “bzr: ERROR: httplib.IncompleteRead: IncompleteRead...” : Bugs : Bazaar
Run command: bzr branch lp:~toykeeper/flashlight-firmware/fsm “O:/Neuer Ordner (2)/trunk” —use-existing-dir
Qt: Untested Windows version 6.2 detected!
You have not informed bzr of your Launchpad ID, and you must do this to
write to Launchpad or access private data. See “bzr help launchpad-login”.
bzr: ERROR: httplib.IncompleteRead: IncompleteRead(34 bytes read)
Traceback (most recent call last):
File “bzrlib\commands.pyo”, line 930, in exception_to_return_code
File “bzrlib\commands.pyo”, line 1141, in run_bzr
File “bzrlib\commands.pyo”, line 673, in run_argv_aliases
File “bzrlib\commands.pyo”, line 697, in run
File “bzrlib\cleanup.pyo”, line 136, in run_simple
File “bzrlib\cleanup.pyo”, line 166, in _do_with_cleanups
File “C:/Program Files (x86)/Bazaar/plugins\qbzr\lib\commands.py”, line 826, in run
File “C:/Program Files (x86)/Bazaar/plugins\qbzr\lib\subprocess.py”, line 1011, in run_subprocess_command
File “bzrlib\builtins.pyo”, line 1434, in run
File “bzrlib\controldir.pyo”, line 780, in open_tree_or_branch
File “bzrlib\controldir.pyo”, line 689, in open
File “bzrlib\controldir.pyo”, line 718, in open_from_transport
File “bzrlib\transport\init.pyo”, line 1719, in do_catching_redirections
File “bzrlib\controldir.pyo”, line 706, in find_format
File “bzrlib\controldir.pyo”, line 1151, in find_format
File “C:/Program Files (x86)/Bazaar/plugins\git\init.py”, line 235, in probe_transport
File “C:/Program Files (x86)/Bazaar/plugins\git\init.py”, line 182, in probe_http_transport
File “socket.pyo”, line 348, in read
File “httplib.pyo”, line 522, in read
File “httplib.pyo”, line 565, in _read_chunked
bzr 2.6b1 on python 2.6.6 (Windows-post2008Server-6.2.9200)
arguments: [‘C:\Program Files (x86)\Bazaar\bzr.exe’, ‘qsubprocess’, ‘—
bencode’, ‘l6:branch37:lp:~toykeeper/flashlight-firmware/fsm25:O:/Neuer
Ordner (2)/trunk18:—use-existing-dire’]
plugins: bzrtools[2.5.0], changelog_merge[2.6b1], colo[0.4.0],
explorer[1.3.0dev], fastimport[0.14.0dev], git[0.6.8dev],
launchpad[2.6b1], loom[2.3.0dev], netrc_credential_store[2.6b1],
news_merge[2.6b1], pipeline[1.4.0], qbzr[0.23.0dev], rewrite[0.6.4dev],
svn[1.2.2dev], upload[1.2.0dev], xmloutput[0.8.8]
encoding: ‘cp1252’, fsenc: ‘mbcs’, lang: None
* Bazaar has encountered an internal error. This probably indicates a
bug in Bazaar. You can help us fix it by filing a bug report at
https://bugs.launchpad.net/bzr/+filebug
including this traceback and a description of the problem.
