Sounds like you need to add a new product - a 30mm x 120 mm strip of bare copper. Label it “LED test fixture, holds up to 12 LEDS” and have a “Do Not Solder LEDS to test fixture” option
Neven,
Glad things are up and running again and I hope you have a good year. I’m very interested in either 3x or 4x (preferably the latter though) 20mm DTP MCPB in 3030 footprint. I need some other things and I’m debating about whether I should wait to order until these boards come out. Do you have a rough estimate on when they might be ready? Thanks.
3x and 4x 3030 will come after new 16 and 20mm boards, so not fast, maybe in March (the main reason is I'm searching for new reliable supplier, last one went into full Chinese mode and just suddenly closed his company and send me only half of my boards -> 1000$+ damage,and delay with new boards release is the consequence).
Sorry, I don't have 4pcs needed for quad, but in my opinion Luxeon V2 would be better fit for these small optics, beam is 2x less floody,price is lower, lumens are not too far behind at 3Amp per LED and you can mix 2x3000K + 2x5000K to get rosier tint.
Thanks for checking Neven!
I know that the V2 will fit better a and that it will still give me a nice tint and beam, but making a triple/quad Luxeon V has been one my goals since I knew about them and started using them, so I wanted the contest mod to have them! Also, I guess it will combine well with the other stuff I’ll put in the flashlight!
Thanks for checking! I will check your store any way for other stuff :partying_face:
Hi led4power can I ask you for advice? I have a problem with ld-4a driver. It worked fine in C8+ host and wf2 until I try to replace the driver spring. I probably messed up something and shorted + and - on battery side. tried to turn it on (it won’t work) so I turned it off and found out it was a short there. I fixed the short but from this moment, the driver gives only 200ma to the led. No modes no settings, nothing seems to work. Don’t you know if I’ve destroyed it completely or if is it possible to somehow fix it? Thank you.
