Wasn’t there a Haikelite (SC26?) nicknamed “Li’l Fatso” when it took a shorty tube for a 26350, but normally comes with the “regular” tube for a 26650?
That was about as small as I’ve ever seen a 26_50 light.
I think the biggest issue is 26650 is simply not a popular format. Even the smallest 26650 light is too big for comfortable pocket EDC. And for larger lights, you get better capacity with multiple 18650.
Also, because 26650 isn’t popular, the cells tended to have not kept up with the latest technology. The best 26650 is not as efficient per unit of volume as the best 18650 or 21700.
I’ve noticed the same problem with 18500. It sucks that the best high-drain 18500 has the same 1100mAh capacity as the best 18350.
I agree on the fact that 26650 cells are not as advanced.
If 26650 cells were as advanced as 18650’s, or 21700, I would guess we should be seeing a capacity closer to the 7000 mah.
I personally prefer single cell lights, so would rather a single 26650 cell instead of 2 or 3 18650’s, but it seems like the market is in favour of multi 18650 lights so there are def more options there.
This beasty starts out glorious, but drops the output pretty much instantly no matter the temperature setting or battery used. I don’t think it even brings the lumen up when the head cools down , you can reapply turbo but that’s all you can do. Between that and a smaller , weaker d4sv2, I pick the emisar by the pattern of reducing lumen output.
There is tons of compact 1 26650 battery lights, For me personally the search is to single out those with a slim profile and sustainable output of no less that 2,000 lm or so. This has been a challenge. There is a couple that come close like mhvast ts70 or thrunite ts20 with around 1700 sustainable, and reportedly some other not really not a whole lot unfortunately. Most of these settle at around 1,000 lumens which is not enough for me….
I would not get any 26650 and expect it to be compact.
That is relative of course.
The other thing is, 18650 cells are more advanced, and usually have way higher energy/volume numbers, as well as higher peak drains.
At least for the price - you may be able to get better 26650s but I don’t consider anything over $5 a cell reasonable.
Yes size is relative. Also perception wise it’s relative to the output it provides. If. 26650 light produces 1000 lumens I may not call it compact but if it produces 7,000 then I probably will call the same size light compact. In general, to me 26650 is still compact as it fits in the pocket easily and I can wrap my hand easily around it and it’s quite short too.
I agree 26650 are not as efficient as 18650, so what? They still have larger capacities and for most applications are available with sufficiently high drain variety. I for one don’t mind paying a few extra $$ to attain a light that I will enjoy more…
7000 lumens would be over 25A, not sure any 26650 can do that
just saying
i have a wuben t50 i think, it;s good - but i almost never use it
it;s a floody 2000 lumens +
I believe orbotronics 26650 can do 25A, but I need to doublecheck. “Edit : I just checked there is an orbotronics with continuous discharge of 22 A”
Is 2000 lumens sustainable with wuben t50?
It runs on outputs less than Turbo too and with a configurable UI you can certainly set it to have outputs more to your liking. I wouldn’t say mine steps down “instantly” either, guess it depends on your definition of instant? I get around 30seconds on turbo before it steps down using a 40A 21700 Samsung battery. On most of the 26650’s I’ve used with it I get longer before stepping down (not by too much, just a few seconds I guess).
I’m not sure and haven’t tested whether it can maintain 2k exactly, but it has decent heatsinking and is a good ergonomic design. It’s essentially a more compact Klarus with a nicer tint and better UI. With 7 emitters and a compact head it’s clearly floody, but then anything with this many lumens and compact would be.
2000 lumens and a sustainable output in this kind of size body, as we know, isn’t that likely with the current generation of LED’s, they all have a lot of heat to dissipate atm, perhaps you’re just a few years ahead in your expectations versus technology!
From what I remember it took less than 30 seconds to drop the lumens, and it didn’t sustain 2000 but I could be wrong. I used a good 26650 battery, maybe I should have tried with a 21700 but it appeared to me the battery wasn’t the problem.
I think you are right, my expectations are a bit ahead of their time:)
But you never know. Up until recently I thought no flashlight of manageable size under $200 can sustain 5,000 lumens until I tried Acebeam x45 which held it completely stabilized for over 70 minutes until the battery died.
Even when I put the light a the top of the ramp (which I’m not sure, but I suspect is 2k lumens or less), it does ramp down after a few (20 to 30) seconds!
It’s not thermally throttling though as the light is still cool - must be a setting or something, there’s no need for it to be ramping down that soon! Even on Turbo it seems to ramp down at about the same time so it’s presumably ramping down based on timing rather than temp - I know that’s configurable…
Yes I remember trying to play with the settings too and they didn’t make sense to me, like it ramped down when it didn’t have to, so I chose in favor of keeping the emisar d4sv2 whose behavior was more sensible, even though it’s tint was worse and lower turbo levels.
