I will make the video together with the MF01 mini review soon. Sorry for delays but A lot of collegues went to holiday around christmas so I had to go to work a few extra days. After that I got flu and just came out of it. I donât had a complete healthy week since start of October. I donât forget it. Or if anybody has questions Just feel free to ask and I will answer if I can. You can send PM also to notice me if I miss a question. Sometimes I doesnât get emails of new posts.
INTERESTED!! 1
Today i receive four copper plates. Now the Mod begins.
Thank you very much!
Danke fĂźr die Info.
Looking forward to your feedback, and please pay attenchion to the installation description on post #1.
Thanks Zozz, donât worry about getting late with the video, health is of course a priority, itâs more important that you are fine.
A short installation video would be very helpful for some, I was thinking of doing it myself, but thatâs just not my expertise.
It`s done! Four Lights are now better then before.
I follow the very helpful installation description. So it was very easy and quickly done.
The Mod is very worth it! Stays much longer brighter.
Thank you very much
Thanks for your feedback, nice to hear,enjoy the full potential of the lights.
It has arrived, Thanks again man of light.
I would like to have 2 pcs. Great idea !
Iâm interested in the second batch. Please sign me up.
For everyone interested, today I updated the post #1 and post #2 with some news on the Status and the 2nd batch.
Please take a look for the latest infos.
It works great, done in 15 minutes.
Interest in one
Thermal test now done
Test conditions:
driver temp sensor on PCB calibrated
set to 50°C
Full AMC heating at 2.4A
Time lapse x5 almost 5 minutes
I found that stock the Anduril firmware seem to quite regulating after first throttle, it may get into unsafe temperatures
In an assembled light a lot of the heat will be conducted away from battery tube, so the bare AMCs will stay a bit cooler
and the AMC heat spreader will stay quite a lot cooler than in this test
1. tested stock upper left
it seems after first throttle the temperature regulation quits and it heats up to 70°C on PCB
2. Aluminum prototype
lower left
3. production sample copper
middle upper and lower
Great comparison, Lexel. The clamp meter is a bit hard to read in the copper spreader test, but it looks like it stays around 2.4A perhaps? Aluminum doesnât appear to be too far behind, but definitely better than running it bare.
Thanks for the test Lexel, great Job :+1:
As expected, the temperatures on the copper version stays a bit lower than on the aluminum version.
Also the heat distribution between the heatsink and the head seems to be best balanced on the copper version.
Yes with both heat spreaders in those 5 minutes the light ran constant, the clamp meter sometimes is acting bad not reading correct or fluctuating a bit, I may have to open it and clean
I am not sure how the temperature is affected in the total light assembly
with it the temperature is definitely a lot lower as the driver gets most cooling connection to the battery tube
But the strange behavior when thermal throttling should be history
Still it seems there is a bug in the firmware when it ran without heat spreader Anduril kept going almost at 100% while the light constantly heated up far behind the set point
I am interested in 2 of them.
Thanks for making a second batch!
Olles
man of light you can add my post link to the OP where I have images of thermal paste and silicone heat pad images added
