My apologies if this was already noted above and I missed it, but does anyone know the diameter and thickness of the lens on the C8F? It would save me a bit of time if someone knows this already. I am looking to put a high quality yellow lens into a C8F - fog and heavy snow at night (star field effect) render my higher lumen LED’s ineffective. I would like to swap out the lens for a yellow lens and see what the result is. Thanks for any info or advice - I am a total novice and am just at step 1 (an idea) of trying to pick my way through any modifications to a light.
Thanks for sharing that info - I will definitely take that into consideration. I am looking for something like the old Hella or PIAA fog yellow. My led fog lights on my car cut glare big time in fog and snow - so I thought can I come somewhat close for a flashlight and maintain lumen output? We get some driving snowstorms where I live and taking the dog out at night - it would be great to be able to turn on a light without it feeling like I am looking into my own light on strobe effect. So I thought I would give it a go and report back if it seemed newsworthy. I can’t do all the fancy things most of you do - but I could make one small contribution to the collective good - and report the result good, bad or otherwise.
Thanks for sharing the specs! This is a huge help on my quest!! We shall see if it turns out to be worthy of a minute of my time - you don’t know until you try.
Once I tried to paint a glass lens with yellow felt pen. If you have a totally yellow lens the light is yellow as well. Half yellow, half transparent is not bad. However, it does not even get close to a real warm white emitter.
The C8F can be purchased on sofirnlight.com with 3000K XP-L or 2700K LH351D.
2700K or 3000K SST20 should be nice as well like in the Fireflies ROT66, E07 or Emisar D4S, D18.
So I just received my Sofirn C8F bought from Sofirn’s AliExpress store on 01\06\2020. The tail cap has the dual springs, but on a freshly charged LG M50T 21700 cell, I’m reading about 2300 lumen on my Texas Ace calibrated lumen tube. One of the holes in the retaining ring looks damaged and has a gash through the ring. Anodization looks like one small area has a rub mark. Will be contacting them. Will be trying a 30T cell on it to see if it’s the batteries internal resistance. Not happy about the retaining ring looking damaged, or the output. Does anyone know if the brass retaining ring from a Convoy can be used in place if the soft aluminum? Hopefully I didn’t get one with an old driver. Will be contacting Sofirn to hopefully get this resolved.
The old driver was still better than the numbers you’re seeing.
Make sure you clean all the contact areas and that the retaining ring is tight. If I loosen mine or cut the spring bypass I get approx 2000. Try redoing the spring bypass as I always get less with the factory job.
Yeah I’m wondering if I do anything to it if they will honor warranty? :). I’ll try tightening the retaining ring, although one of the holes is damaged so not sure how tight I can get it. The bypass can be redone too. As long as the driver is correct the rest can be corrected (I hope)
