I assume the OP is talking about li-ion cells. I have batteries in 10 or so lights scattered around the house that are fully charged all the time. I also have about 15 that are charged to around 4.15v in the event that I need a battery immediately, and another 50 or so laptop pulls that I keep at around 3.7 volts.
Yes. Anything in a drawer is locked out.
No. I have more lights than batteries and I prefer to store batteries in the fridge, though I keep a number of cells in room temperature.
Only the ones with mechanical lockout. I just did my tri- monthly check on them and found 2 lights discharged down to around 3.51v so something was making contact. There are 2 that don’t have mechanical lockout that were at 4.12v after 3 months.
Maybe half of my lights are ready to use with full charge batteries and i have a bunch of batteries (pulled from laptop or other appliances battery packs) in stock, some at full charge, some at "storage" level
All my lights have charged batteries. All my AAA lights have lithium primaries.
The stored Li-ION lights are mechanical locked out (if possible).
If not possible (Cu, SS, Ti) I put a small plastic cup under the tailspring.
Only the lights in my rotation are not locked out.
Flashlight’s no use without a cell in it
I don’t keep many lights so all have cells, the ones used infrequently are locked out & partially charged.
I have some 250 lights, all with charged cells in them ready to use. Also have quite a few cells on standby, charged and ready to go. Over 300 cells.
I do. They don’t leak, right?
where dem poll yo?
I kept them in my flashlights cuz I only bought enough for each so no storage boxes
I do the same.
All aa and aaa are loaded… lion (I only have 4) are empty with bats in the same case.
Usually i don’t.
Only the lights i want to use have batteries in them.
I keep my batteries in the refrigerator nowadays.
I usually store them close to discharged.
A few…not all
Phooaaaa, man. That allows you to use only few twice a year
All loaded. LiIon or NiMH. No alkalines.
Old lights have their cells removed and get stored away in a box. Apart from that, just about everything has cells in. There are some spare cells sitting at full charge, and some more sitting at storage voltage.
That is new to me. What are the benefits and could you describe your method of storage ?
Thanks :+1:
I have 10 or 12 active, meaning yes they have batteries.
If i am just going to store the light, I will not have batteries in it.
Less chemical action going on when cold.
Apparently Li-ion cells can degrade when they’re kept warm.
