So far Vapcell had a good feedback. Let’s see what HKJ and Mooch will say
WOW this performance is incredible! If Mooch or HKJ confirms it, it is the new king of 14500. We should be able to expect 1,200 lumens from a GT Micro and still get good runtimes! :+1:
I do not have the cell in queue (I hope it is a yet) and my test station for these batteries are unreliable at the current time.
The problem is either the power supply (used for charging) or the relay (That connect the power supply), I am trying to find out which on and fix the problem, but it will take a couple of days.
Anybody knows which is the actual manufacturer of Vapcell 14500s? The Gold ones for example?
Barkuti:We’ll see once it gets in the way of HKJ’s or Mooch’s steamroller.
Yup, let’s wait and see.
FWIW, I only have two of their cells (16340), and based on what my Lii-500 reports, their capacity is notably lower than what Vapcell claims.
Do you mean the recently released 8 Ampere ones?
I’ve got 4 pcs coming my way, but i wondered why they had a price drop already (which made me decide to order them)
Pete7874: Barkuti:We’ll see once it gets in the way of HKJ’s or Mooch’s steamroller.
I didn’t know they released an 8A version. Mine are 7A:
Got my 16340 cells from Illumn. [image] Capacity test using 500 mA discharge current on Lii-500: [image] . [image] IR, measured using a DMM and resistors: Cell 1: 0.21 Ohm Cell 2: 0.20 Ohm
Latest release Vapcell 21700 5600mah 12.5A battery - #203 by Pete7874
Oh, you’re right, they are rated 7 Amperes.
Yes, it’s those cells.
Perhaps they’ll have a bit more capacity after a few cycles.
I just retested mine. Capacity is down by a few mAh, but more or less the same as new.
Can we say word or two about this in AliExpress Vapcell Store? Is it “real”?
Description: Vapcell original mini lithium 3.7V battery INR 14500 1000mah 10A rechargeable battery for flashlight / power tools
Url: 14.02€ |Freies verschiffen Vapcell original mini lithium 3,7 V batterie INR 14500 1000mah 10A akku für taschenlampe/power werkzeuge|Wiederaufladbare Batterien| - AliExpress (AliExpress Vapcell Store)
…and as “proof” in description at aliexpress used this graph of completely different batteries (Vapcell ICR14500 1000mAh (Gold) 2018) rated by HKJ:
Sorry, that’s too careless
Thank you very much for your reminder
I contact sales customer service to change the picture
Jerommel:Perhaps they’ll have a bit more capacity after a few cycles.
I just received 4 pcs of these, i just put them in my Lii-500 on NOR test.
I’ll report back.
Thx! ^^^
1st run on Lii-500 NOR test (4.2 - 2.8 Volts)
[1] 711 mAh
[2] 721 mAh
[3] 750 mAh
[4] 742 mAh
Doing second run now.
Okay, 2nd run finished.
I swapped the cells in the charger, so that [1] was now in slot 4, [2] in slot 3, [3] in 2 and [4] in 1.
[1] 732 mAh
[2] 747 mAh
[3] 737 mAh
[4] 734 mAh
So it seems there is some difference between the slots of the charger.
Average of 1st run: 731 mAh
Average of 2nd run: 737.5 mAh
It’s ridiculously late here, so i put them in for a 3rd run, i’ll see the results tomorrow.
I put some nickel plated neodymium magnets on the minuses to increase the force of the clamping of the slots.
I must sleep now.
See you tomorrow.
Oh, i forgot about this… ^
The last NOR run was a little better, but not a lot.
I wrote down the results, but i can’t find it anymore…
Anyway, AliExpress page of the new INR14500 shows the graph but it now says “HKJ test” above it.
Hmmm….
hm so not really close the stated 1000mah then? should be marked 800mah then imo.
Mooch said he'll run some tests on 14500 10A :))
Would these work in the GT Micro or is 10amps to much for it? I am using the gold 14500 vapcells and they seem much better then my Efest 700mah in my GT Micro.
Mooch said he’ll run some tests on 14500 10A :laughing:
That is great :+1:
Thanks ,H10 14500 10A have much power than gold 14500
Correction: “H10 14500 10A has much more power than gold 14500”.
I just want to make sure its not to much power for the GT Micro, I would hate to smoke the emitter
