Just for clarification (maybe I missed something), you have pictures with the thermal pad on top of the 7135 chips and a picture with the thermal pad on the bottom of the copper plate. Do you recommend putting it in both places or is one better than the other?
Not necessary. Those two pictures are two different try. Even if you add layers you make the thermal path worse. The second and current one is where I putted the thermal pad on the copper thing and cutted it exactly the shape it has. And I used thermap paste on the side of it. Then grabbed it with tweezers to put it in place.
The heatsink plate is generally designed for usage with thermal compound paste, I would still recommend to use it this way.
Both thermal contacting methods will work well, if the installation is properly done and there will be no differences in the runtime performance or thermal effectiveness.
Good quality thermal pads are mostly more expensive than a high quality thermal compound paste.
If I have the lamp and the copper plate, I consider whether I should use a graphite cooling pad instead of the MX4 paste because of the mess when I open the lamp again, what do you think.
Graphite cooling pad should conduct better than a thermopad?.
What is the distance between the copper plate and the housing?
Graphite pads are electrically conductive, might not be a problem in large CPUs where you just cut them short near the edge of the professor, but it might be a problem with this small AMCs. Plus it might be hard getting them to touch the copper and all chips without touching the PCB and any component they might short.
As Dr. Phillip has already explained, graphite cooling pads are electrically conductive, so not optimally suited for this application.
If you mean the distance between the outer circumference diameter of the heatsink plate and the head body, there is only a gap of 0.2 - 0.3 mm in the production version of it.
Ok, so I’m going to buy some thermal paste (maybe like the MX4). I see a lot of area to cover and some looks heavily applied in the pictures. How much do I actually need. Will a 4gram tube be enough? An 8gram tube? And whatever paste I get should not be electrically conductive (even minimally) correct? Please excuse my inexperience in this type of thing.
