Hunters Green…. Sadly i think Nightmaster beat us to it a few years back with their green envy series
They were charging obscene money too!
I just ordered the 20W green flat for building a pill for my B158 for just that!
I tried it, it has the strength but I was disappointed with the color, because its is converted gree it is quite light green tint, almost looks like yellow. Cree XPE has much nicer tint, darker green, more intensive, but lacks in strenght significantly.
I also have Osram blue flat, 1x1 die, but did not test it in the flashlight.
Stuck one in a Jax with a 5amp driver just for curiosity…. not the best image but gives you an idea… thumbs down from me green light on green background next to useless past a hundred meters. ill be sticking with white.
Are you kidding? That looks great! You gotta to use that with riflescope or binoculars and then you’ll see
The beam in your Jax is awesome, the color though …
Looks like typical Cree tint.
It appears you have the HX and HL confused. Nice mod though! Mini throwers are a favorite of mine…
I see that Boost HL appeared on the Osram site finally:
YES i feel one coming on also :+1:
so where can you buy the HX on a 16 mm ??
Nowehere so far.
There was a mention of them being sold on some Asian flashlight forum.
L4P has samples but not on sale yet.
Vinh has some but not on sale either.
Where can I buy this? Oslon Boost HL
I’m a store and wanting to offer a few custom built C8’s
Which driver is best suited?
Is this the same
http://kaidomain.com/Osram-KW-CSLNM1-TG-White-5600KLED-Emitter?search=osram%20kw
Almost, it is the same die in a smaller 3030 package, the boost hl is a 4040 package and handles a little more current and output.
Green emitter seems nice for faking an alien invasion
Some days ago I showed that I modded an Eagle X3R here, with a Osram White Flat (W1) led!
Now, here are some photos of the beam!
It reaches 400m without problems, even if the centering is not 100% perfect!
This is a very nice host for these throwy Leds, despite all !
90m
175m
200m
280m
400m
Comparison with:
Convoy S2+ (XP-L HI, SMO) >>>> X3R (Osram W1, SMO) >>>> FW1A (XP-L HI, OP)
What are the internal reflector dimensions of the x3r? Awesome beamshots btw!
Thanks It was a good and “clear” night to take them, so it helped
About the reflector:
bottom hole - 7mm
top hole - ~25mm (approximately, I didn’t take it out again because as the reflector and bezel are screwed together, the Led would get de-focused again)
height - ~25mm as well (measured from the outside based on the level of the shelf and the top, below the thick lens and thick o-ring).
The bigger inconvenient of this light is the bezel and reflector screwing together, as it leads to some move on the gasket and MCPCB.
Despite this…it throws pretty well, more than the previous configuration on a Convoy S2 w/ SMO reflector
