What Legoes with What?
Nope...completely different threads than any other S2
yes but myabe others brand with square threads can fit,would know wich
Am I the only one who found out that a euro coin can become pretty stuck inside a D4 bezel? :person_facepalming:
It just so happens that I'm on the bus on my way home and I also happen to carry my D4V2 and 90% sure that I should have some change in my wallet. Now.. let's see if no one is looking my way and..
Nope, just joking.. But, all of a sudden just realised.. my trip home seems to have gotten that much longer for whatever reason, I wonder why that could be, hmm..
Nitefox ES10K and Lumintop Tool AA V2.0
Functionally “legoing”
Along with Fenix E01, the Sofirn C01 legos perfectly with the Klarus Mi02.
Klarus Mi02 (left) Sofirn C01 (right)
Side-by-side
Head’s Off
Heads swapped
Anyone know what other lights have threads that Astrolux S41/S42/S43 (Mateminco S01/S02/S03) tubes would lego with?
Trying to find more attractive 18650 and 18350 tubes for a new Astrolux S43S that is on it's way. (Copper head, alu body version).
Both the S41S and S42S have editions with lovely Stainless/Coloured tubes, tails and bezels. But they never made these complete editions of the S43.
I have already ordered the official 18650 tubes in SS from Banggood which are available separately at reasonable price.
They also have matching tails in SS available separately - but only the S41 version with button.
The S42/43 flat buttonless style doesn't seem to be available separately. Neither do the shorter SS/Coloured 18350 tubes seem to be individually available.
I've contacted Mateminco (OEM) to see if they can supply these body parts separately. Besides, their stock S03 tube (Black Alu) is much nicer than the completely smooth plain tube they supplied for the Astrolux S43. The Mateminco version has rather cool finger indents!
Would the multitude of available tubes (many of which I already own!) for the BLF A6 / Convoy S2+, work with the Astrolux?
Even better, would the Lumintop FW3A/FW1A tubes or Bezel lego with any of these - A6/S2+/Astrolux S4x?
There are beautiful copper, SS & Ti 18350 tubes available separately from Lumintop that would be perfect if they work...
Many thanks as always.
I'm sorted with the Stainless tubes now on an Astrolux S43S - but still can't obtain a matching bezel.
Result is that it will lego with the currently available (from my own experience) BLF A6/X6 and Astrolux S1/X6 tubes. (NOT Convoy S2+ tubes.)
So last black section left is the head bezel! Have written to Mateminco and await reply even if it has the S41 or S42 text etched.
In the meantime, would anyone who has an Lumintop FW3A/FW1A and an Astrolux S41/42/43 be kind enough to check something for me:
Would the Lumintop FW3A/FW1A Bezel lego with the Astrolux S4x?
If the threads work I can get one of these, even if it needs padding to hold down the lens.
Thanks as always BLF community!
Not having the Astrolux, I would say NO, just because of the diameter! The S4x Lights are quads, while the FW3A is a triple.
The diameter of head and the bezel is probably larger on the Astrolux lights!
Maybe someone can check this, but I guess my hint is correct!
That was my assumption too, however the bezel on the S43 actually narrows much more than the full width of the copper head. (Unlike the FW series shape where the head is uniform all the way to the bezel.
I’ve measured the Astrolux bezel as being ~26.9mm - 27mm. (Diameter across the widest point).
Please could you see what your FW3A is, even if just with a ruler? Then I know whether to bother looking into the threads!
Ta very much.
These are the threads of the FW3A and the mesaures of the head threads an bezel (in and outter diameter)!
I hope it helps :+1:
Wow thanks for all that!
It certainly helps me save a fiver on a SS bezel that wouldn’t fit the light! Removing from my basket now.
You were spot-on - I had no idea the FW3A head would be that much narrower.
Glad it helped :wink:
The quads are larger than the triples, unless the flashlights are highly moded to be narrower. Vinh (Skylumen) made a FW3A fit a quad MCPCB and Optic, but he had to “trim” that to fit well. Using normal optics and MCPCBs, the quads will always be larger.
You can check if the bezels of the Emisar D4V2 or KR4 fit, but those will be probably larger and the thread will be even less similar. But maybe someone can help on that :wink:
Hmm, I wonder, does this count as Lego.. ?
Sure, you can see the Mini-GT as a fair sized tail led for the D4V2.
Hmm, you must be correct, there's a reason for it being called a "Mini", right.. ?
Which 18350 tube will fit?
https://m.aliexpress.com/item/826041411.html
A regular S2+ 18350 tube will do! I have one in mine!
Check this post: What Legoes with What? - #138 by MascaratumB
Does your S2 have the yellow/glow in dark tail click switch? Maybe Simon has changed the S2? S2
Simon still denies they will fit the S2
There are now two versions of the 18350, rectangular or trapezoidal
S2+ Gray/Black Tube
Mine came with a black rubber tailcap!
It was this one: 11.04€ |Convoy S2 taschenlampe host, umfassen OP reflektor, pille, kopf O ring,glas, frühling, lanyard|flashlight host|op reflectorconvoy s2 flashlight - AliExpress
The tube was the one you linked, and by that time there was no distinction :frowning:
Simon also said that to me at the time, but the tube fitted the S2 and the S2+ .
