What did you mod today?
Seriously CRX, you’re an animal :+1:
I don’t know why I even bother but FWIW, since I gave away all my C01’s at Xmas and they’re basically out-of-stock. I decided to check out the Klarus Mi02 (currently on sale at SBFlashlights). Turns out the Mi02 is perfect lego with Sofirn C01. Took the occassion to swap out the old Nichia CS for a hi-cri Yugi 3K.
Unlike Fenix E01 and Sofirn C01, no potting, just some white adhesive that softened when heated.
Before (left) and After (right) (WB was set to 5000K so Nichia CS “angry blue” actually doesn’t look bad in photo)
After LED swap I applied a conformal coating to protect circuit board from water, not as protective as potting but hopefully better than nothing. And after assembly a light solder coating at all contact wear points.
EDIT - I did a second Mi02 mod and discovered that all Mi02’s are not the same. My second unit was fully potted?! It came out with some heat but swapping the “angry blue” Nichia CS with a hi-CRI required laboriously picking away at the potting compound. I also replaced the 7.5Ohm resistor with a 10Ohm to reduce current slightly.
Heavenly work from CRX again! And descending back to us mere mortals: nice job pc_light, good to see that all those 5mm lights lego with each other. I still hope for a C01 host version soon.
Built a light engine for a Crelant 7G5 and used a new 90.2 in it… totally forgot about the high power glitch in a Bistro driver and didn’t address the driver I’d built for it years ago… it glitches going into level 6 of 7. Ugh! Going back in this morning to correct that memory lapse.
Be careful! I don’t think you are supposed to operate on yourself :slight_smile:
New CFexpress card installed through left ear, memory and read speed greatly improved! :smiley:
Ok, so for the Crelant 7G5 SBT-90.2 build I got the new driver built and the fix for Bistro on it, rebuilt the light and am very pleased with the results…
A big part of the choice for using this light was the tail end, as it holds a heavy duty Tofty switch. These were built in England some years back and were $25 apiece! Worth it though when you need a quality switch that carries serious power, as this light now does… A Samsung 25S cell gives 23.2A at the tail for 4240 lumens out the front. Lux is 352.5Kcd for 1187.43M throw. I Like It! :smiley:
I built a light engine/heat sink to replace the emitter shelf area and I made it about an inch longer than there was room for, bored the end of the battery tube to accept this extra length and tie the heat sinking into the battery tube. :wink:
I needed a spacer as the tube is still longer than an 18650, so I used a .458 Ham’r brass soldered onto a switch board, the board keeps the spacer centered and the heavy BlueSword spring contacts the brass screw in the Tofty switch. :smiley:
In the Crelant 7G5 the reflector has a 53mm opening and is approximately 55mm deep, this yields an excellent hot spot that is fat and well defined, the beam profile is a tube/column of light much like a very fat laser. Will get beam shots later tonight…
What with multiple interruptions it was somewhat of a hassle to build, but well worth it in the end! A great update to a nice old light, very happy with it’s performance… I just need to find some more Samsung 25S cells now. lol
Ooh la la :heart_eyes:
Very nice! If the upcoming FT03 with this leds performs similar I will be a happy camper! :slight_smile:
Past 1month mods
Removing F from H17F
:smiling_imp:
CRX DQG Titanium 10180, 10280, 10440 Pocket Charger/ Spare cell carrier.
This titanium spare cell/ pocket charger, being modular can carry and charge 10180, 10280 and 10440 cells.
It has a 100mA charge rate.
Made from a DQG titanium pill capsule & extension pieces plus a charger unit from a 10180 rechargeable flashlight.
The section with the brass rings can be removed & used to extend the laser to use a 10440 cell and the remaining sections will still house the other 10280 cell that the laser normally uses.
This is made to accompany my:
CRX CuTi Osram PLTB450B 450nm 1600mW - OFBD 1.6A - 10280 - Mo Tail Sw - 1600mW Laser.
10280 cell version:
10440 cell version:
I also made another couple of wee titanium gadgets for my keyring.. :)
CRX Titanium Magnetic Extendable Keyring Pen
CRX Titanium Magnetic Extendable Keyring Toothpick
Nice stuff CRX! Have you already seen your designs nicked and produced in China? Maybe start the CRX Gadget Company.
It was sort of the other way round this time.. :D
I always had the True Utility telescopic pen but wanted a titanium version, then I saw the toothpicks when searching.
I think I did invent the worlds smallest extendable titanium ferrocerium rod though :)
Since I had another Luminus SBT-90 Gen 2 to do something with, I modified my scratch built 124mm reflector light, DBC-07.
A write up on it HERE.
So now it’s the largest BLF Q8 ever! lol
And it easily hits a hay barn at 1.02 miles distant…
I tested it with Samsung 18650’s, both 35E and 25S, it makes from 4300 to 4800 lumens and a quick 5M test (too close I know but it was still daylight) shows 1.71Mcd! :smiley:
Edit: Worth mentioning that the beamshots here and on the write up were done using the 35E cells at lower output. :wink: I have new 25S cells arriving today… the ones I tested with have been, well, Ham’red!
Today I put a Oslon HX Boost HL in my GT Micro. I had bad luck getting a good focus, but it still more than doubled in throw compared to the XPL-HI NW.
It out-throws the FT03 with 50.2.
Before with stock XPL HI NW:
After Oslon HX Boost HL mod
I think that’s the HL.
Yes, Boost HL.
WB daylight
Another Jet II MK. Ladies and Gentlemen, this is my very first reflow :beer:
Some time ago I modded my C8 (SMO to OPR and XP-L Hi to XHP50.2, A6 driver) and was left with a very nice XP-L Hi U6-4C MCPCB. Now this LED resides on the original board of the Jetbeam. I’m really proud :blush: .
Edit: Yeah, I see it’s not centered :weary: :person_facepalming:
Looks good to me Unheard. Congrats on your first reflow!
Thanks :slight_smile: . Now I know why I ordered some 219B :smiley: .
