Sorry, I was just referring to the specs. I have the orignal run Ti which I think many of us got for $5 Its my most fav middle of the night bathroom use light!
If something is 0.04lm still does not mean it is directly comparable to another light because of many reasons.
-Almost all the time all these ultra low lumen measurements are incorrect
-Not all LEDs have the same efficiency, one LED mode needs one current for the same lm value, another LED needs another current for the same lm value as the other LED model.
-Not all drivers have the same efficiency, actually ultra low currents are highly inefficient on pretty much all drivers, so extrapolated runtimes which all manufacturers offer are only that.
-Different cells types (chemistry, capacity, self-discharge, etc) offer differ runtimes.
So comparing flashlights based on manufacturer advertisements is as unrealistic as it gets.
I just measured the lowest moon setting of my Manker E02 with 4000K 219C at 0.002 lumen, right at the limit what I can measure. Unfortunately the current drain stays high at 5.56 mA because the MCU is kept awake, so in 6 days your battery is empty (could be 14 years if it was just the led that used current).
These luxmeters use silicon sensors that are as far as I know lineair in their whole range. At least I never noticed alinearity and I also know no sources that say otherwise (I did search for it)
My Red Manker E02 w N219c, is my new AAA Firefly King.
No PWM, and it is High CRI.
I dont worry about runtime.
I use rechargeables, and turn my lights off when Im sleeping.
by my meter the 21 steps of available minimum modes goes from
<0.005 lumens, up to 0.6 lumens… hard to beat those options imo
Surprisingly good!
My meter is giving the same minimum lumen level as djozz, using totally different equipment, thousands of miles apart.
in any case, in the photos that show more than one light at the same time, it is pretty obvious that the E02 goes significantly lower than the Ti3, and even goes as ridiculously low as the Jetbeam Rotary in this post. (The rotary changes modes much more easily though)
At this point, the question is, how low do you want to go?
cause the E02 can go a LOT lower than most people would ever want, most of the time…
(and there is no AAA Zebra option, and zebras flicker, the Manker does not)
[QUOTE=maukka;5094246]Just an update on Zebralights since I got my faster sensor.
It’s not PWM as discussed previously, but don’t be surprised if you see flickering on camera.
I don’t remember the exact modes these were measured from, but it is similar on some L and M modes. The frequency changes depending on the mode.
In all the pictures horizontal center line is zero output. So it’s more than just a very low amplitude flicker especially on the SC5Fc.
H600Fd
SC600w Mk3 HI
SC5Fc
[/QUOTE]
imo zebras long runtime is due to the way the LED is being pulsed, very quickly, brighter and dimmer… most people dont notice in casual use … the pulsing is more a concern to me when the light is used as the only ambient light source, for long periods…
The only thing I wish was different on the E02 is the weight. It is twice as heavy as my other AAA aluminium lights, and weighs the same as my Copper Tool (which lacks firefly though).
The heavy weight, is what is stopping me from buying the Ti version of the E02. (1/2 oz heavier than my Copper Tools). How long can someone that values programmable firefly resist?.. Not sure… I will get back to you on that…
I read the low is 1 lumen on that U11
whatever works for your situation is the right thing
you are probably dealing with non black of night adaptation… with more ambient stray light affecting your dark adaptation
the lowest firefly on the Manker E02, is only useful to me when I wake up in pitch black darkness, to see the toilet paper, before I go back to sleep
that firefly is definitely useless during the day, I cant tell its on, unless I hold the LED up to my eyeball
tritiums are also useless during the day, but amazingly useful to see a light on the nightstand, when I wake in the middle of the night…
you may not be of an age that wakes up multiple times needing to pee
thats when firefly became relevant to me
I dont like turning on the bathroom light, in the middle of the night
hope thats not too graphic
different strokes for different horses
[/quote]
Sorry Jon the Thrunite Ti he's talking about is a 2 mode crusher in aluminum with like 5 colors not the silver three mode light you own .
https://budgetlightforum.com/t/-/9006#new
Also a thrower in a moon mode vs a floody light may have the same numbers and yet look like one is much brighter .
I use rechargeable and never really sleep with the light on, but during the summer, I travel on long motorcycle trips and camp each night. My bike (Harley Ultra Limited) has lighter ports and even a usb port, so I can typically charge during the riding day.
However, in the fall and winter I backpack and camp where there is no.power and no ambient light. I have a 21w solar panel for sunny days, but I want to take lights with me that can hold up to several days use without charging.
It is amazing how much light .5 or 1 lumen can be with a diffuser in a tent when there is no ambient light (overcast…no stars or moon). I camp where the nearest town (population 298) is 15 miles away, so it is DARK!
Has anyone on BLF ever proposed a “Moonlight/Firefly Challenge?” Perhaps a challenge in which we post about activities and duties we were able to perform using the moonlight mode? It would be interesting to see what folks could accomplish using this mode on their light. Last night I left my Thrunite T1 on moonlight mode when I went to sleep. I placed a diffuser on it and woke up while it was still dark outside and was pretty pleased with the amount of light .5 lumens gave me.
I spent 20 days hiking the JMT with a Thrunite Ti-3. I will admit I did use the low mode occasionally, but 90% of the time I used moonlight in camp for cooking, inside my tent, or just in my sleeping area when a tent wasn’t needed. One Li primary lasted the whole trip, and is still in the light.
Glad to see someone else mention the Ti3 for the very nice moonlight. Used to be my favorite as well. Currently would be the Tiara. Moonlight modes are kind of an interesting thing to me. As far as I am concerned they are essential for an EDC light. What a moonlight mode is and what makes it good is another story. Bottom line for me is that I can see what I must in the dark without disturbing night vision or those around me.
It took me a while to appreciate the low moonlight mode on the Tiara as it is noticeably lower than any other light I have. The second moonlight mode is rather amazing to me in that it is a very useful amount of light that doesn’t mess much with night vision but it would disturb a sleeping partner or those around you at a concert if you want to read the program so I wouldn’t really consider it a moonlight mode but more of a very very efficient low light mode. It is good to have both.
